Homework Help: Simple, yet annoying, proof
  1. Jan 7, 2010 #1
    [tex]a+b = ab = a^b[/tex]
    Prove that [tex]a=b=2[/tex]
    2. Relevant equations
    3. The attempt at a solution
    Ok, I've tried this for more than an hour now, but can't figure out how to do it. I guess it could be done with Lambert's W-function (?) but this task is given on a much lower level. They haven't even learned how to prove that when x is a odd number, then x squared must be odd aswell. So this must be really simple, but still I can't figure anything out.
    I've tried to take the equations and isolate a or b, and then insert it into one of the other functions, but I've gotten nowhere. I really hope someone could help me se the obvious here.
  3. Jan 7, 2010 #2
    This is part of the proof:
    I'm in a hurry continue later(=
    [tex]a+b\equiv0(moda)[/tex]
    [tex]b\equiv0(moda)[/tex]
    Therefore,a divides b
    [tex]a^{b}\equivab(modb)[/tex]
    [tex]a^{b}\equiv0(modb)[/tex]
    Therefore,b divides a
    Concluding that [tex]a=\pmb[/tex]
  4. Jan 7, 2010 #3
    Hurkyl
    Staff Emeritus
    Don't give complete answers. :grumpy: But your approach can't work anyways, because it doesn't say anything about non-integers.
    I presume that you're supposed to have an idea inspired by the qualitative behavior of addition vs. multiplication vs. exponentiation....
  5. Jan 8, 2010 #4
    ehild
    At low level I would mean to substitute the values given for a and b and see if the relations are true :)
    ehild
  6. Jan 8, 2010 #5
    tiny-tim
    Hi Norway! :smile:
    (try using the X2 tag just above the Reply box :wink:)
    Here's a start …
    the bit on the left gives you an ab - a - b … does that remind you of anything? :wink:
  7. Jan 8, 2010 #6
    HallsofIvy
    ?? There were no "values given". The problem is to show that his is true for all numbers a and b.
  8. Jan 8, 2010 #7
    To be hones - no, it doesn't. :(
    First thing that comes to mind are those (a+b)2 rules, but I guess neither of them fits in here.
    Then I think; "So a and b multiplied minus a and b is zero. That must mean that a+b=ab", and we're back to the start...
    Sorry.
  9. Jan 8, 2010 #8
    tiny-tim
    Try adding a constant to it, and then factoring it. :wink:
  10. Jan 8, 2010 #9
    Geez, I still don't get it.
    I'm trying to look at this task like I have no idea what a and b could be, I'm not doing anything wrong there, am I?
    Ok, [tex]ab-a-b=0[/tex]. If we knew that a=b, then OK, but we don't. That's what we're going to prove. Right?
    Or wait;
    [tex]ab - a - b + 1 = 1 \ \Rightarrow \ (a-1)(b-1) = 1[/tex]
    Was this what you had in mind?
    Then what? If they had to be integers, then sure, but they don't. Any more hints would be greatly appreciated. :D
  11. Jan 8, 2010 #10
    tiny-tim
    :biggrin: Woohoo! :biggrin:
    ok, now have a go at the bit on the right … ab = ab
    how can you get an (a - 1) or a (b - 1) out of that? :wink:
  12. Jan 8, 2010 #11
    Hi everyone,
    tiny-tim, I tried: ab=a^b
    a-1=a^(b-1)-1 and since b-1=1/(a-1), then (a-1)(a^(1/(a-1))-1)=1...
    but it's not a likeable equation,is it?
    is there any other way?
  13. Jan 8, 2010 #12
    tiny-tim
    Hi penguin007! :smile:
    (please use the X2 tag just above the Reply box :wink:)
    I managed to get as far as ab-2ba-2 = 1 …
    not sure what to do then. :redface:
  14. Jan 8, 2010 #13
    Hi Hurkyl!
    You are true i've neglected the non-integers. But if it is non-integers, i do not know how should i deal with my proof.
    Hi!Norway can you specify if a and b are real numbers or solely integers?
  15. Jan 8, 2010 #14
    Hi! The task was given exactly as I gave it to you. I would guess this means all numbers, but maybe it was integers. As I said, this was given on a relatively low level, to students who has never ever done any proofs before.
    Thank you guys.
  16. Jan 8, 2010 #15
    ehild
    Norway, was it said that "Prove that a=b=2" with the same words? Or was it meant like that: prove that a=b=2 satisfies the equations above? A simple substitution of a=2 and b=2 into the equations is a complete proof then, the derivation of the solution is not necessary. If the question means "prove that a=b=2 is the unique solution", that is a nice problem for high level, as this thread illustrates it, but not for beginners in maths.
    ehild
  17. Jan 9, 2010 #16
    The expression you got seems to be interesting tiny-tim but I didn't manage to exploit it.
    We can try to introduce the function f:=x->(x-1)*(x(1/(x-1))-1) and then by studying the variations of this function, we would show that the equation (x-1)*(x(1/(x-1))-1) =1 has a single solution (x=2, which would give us a=2); BUT:
    1-I do not guarantee the study of f is easy;
    2-this problem seems to be a more arithmetic one and therefore should be solved differently;
  18. Jan 9, 2010 #17
    Well, it said "Given [tex]a+b=ab=a^b[/tex], prove: [tex]a=b=2[/tex]"
    But yes, I do start to wonder. They can express themselves quite sloppy sometimes, especially on lower levels. I just saw a good try on this on a Norwegian forum of maths (that's why I posted this here, I saw this question, and was unable to help, even though I'm on a much higher course :blushing:).
    [tex]ab = a^b[/tex]
    [tex](ab)^b = \left(a^b\right)^b[/tex]
    [tex]a^b b^b = a^{b \cdot b}[/tex]
    [tex]b^b = a^b[/tex]
    [tex]a = b[/tex]
    [tex]a+b = ab[/tex]
    [tex]2a = a \cdot a[/tex]
    [tex]a = b = 2[/tex]
    Obviously this turned out to be wrong, but I guess it was still a nice try.
    They said they found a solution to this now, so I'm going to check out the link they gave and then check back here.
  19. Jan 9, 2010 #18
    Okay, I just reviewed the other solution, and I can't see anything wrong with it. Maybe you guys can?
    [tex]ab = a^b \ \Rightarrow \ b = a^{b-1}[/tex]
    [tex]a+b = ab \ \Rightarrow \ b = 1 + \frac{b}{a} \ \Rightarrow \ b - 1 = \frac{b}{a}[/tex]
    Therefore:
    [tex]b = a^{b-1} = a^{\frac{b}{a}}[/tex]
    [tex]b = a^{\frac{b}{a}} \ \Rightarrow \ b^a = a^b[/tex]
    [tex]a \cdot \log{b} = b \cdot \log{a}[/tex]
    [tex]\frac{\log{a}}{a} = \frac{\log{b}}{b}[/tex]
    [tex]a = b[/tex]
    Is this correct here? Why not?
    [tex]a+b = a^2 \ \Rightarrow \ 2a = a \cdot a \ \Rightarrow \ a = b = 2 \; \; \; Q.E.D.[/tex]
  20. Jan 9, 2010 #19
    It's not. Because you believed too much in the guy who said it was strictly increasing. If you actually take a look at the graph, you'll see that a=b could mean a ton (infinite?) of possible (a,b) pairs.
  21. Jan 9, 2010 #20
    tiny-tim
    Hi Norway! :smile:
    That requires that logx/x be single-valued.
    Unfortunately, it has a maximum value of 1/e at x = e (2.718…),
    so loga/a = logb/b does not imply a = b. :redface:
    EDIT: uhh? are you two different people (or countries)? :confused:
  22. Jan 9, 2010 #21
    Ha ha, no, I just replied to myself, because I asusmed the guy who posted this proof was telling he truth about it being strictly increasing, without even having looked at the function. Then I checked it out, and realized that it was wroong. Still a nice try, though.
  23. Jan 10, 2010 #22
    Let me just ask you; is there anyone here who knows how to prove this at all?
  24. Jan 10, 2010 #23
    Hurkyl
    Staff Emeritus
    Here's the sketch of the first elementary complete proof I've put together.
    I hope you'll allow me to assume a is positive, so that we don't have any worries about whether ab is well-defined.
    First solve ab=ab (e.g. with logarithms): this gives
    a = bb-1
    Then a+b = ab gives
    bb-1 + b = bb
    or equivalently
    1 + b2-b = b​
    Checking the three cases b <= 1, 1 <= b <= 2, and 2 <= b yields b=2 is the only solution.
  25. Jan 10, 2010 #24
    tiny-tim
    Hi Hurkyl! :smile:
    No, a = b1/(b-1).
  26. Jan 10, 2010 #25
    Hurkyl
    Staff Emeritus
    My first idea's simplest implementation, unfortunately, uses calculus to get the identity I wanted, and works out like this:
    Solving a + b = ab gives
    a = b/(b-1)​
    Our assumption of a > 0 implies b > 1.
    Plugging into ab = ab gives
    (b-1) log(b-1) = (b-2) log(b)​
    If we set f(x) = (x-1) log(x-1) - (x-2) log(x), we see that the equation f'(x)=0 simplifies to
    0 = 2/x + log (1 - 1/x)​
    which has no solutions. Therefore f is monotone and has a unique zero on x>1: x=2.
    NM I messed this one up too. I feel silly making two arithmetic errors in a row. Terrible ones even -- I shouldn't be allowed to do math today:redface:
