Simplify Sinusoidal Function 2sin(wot+45)+cis(wot) to Acos(wot)
  • Thread starter noname1
  • Tags
    Sinusoidal
In summary, simplifying a function in mathematics means to write it in a more concise and manageable form without changing its value. A sinusoidal function is a mathematical function represented by a sine or cosine curve and commonly used to model periodic phenomena. The number 2 in 2sin(wot+45) represents the amplitude of the function, which is 2 units. "cis" stands for "cosine + i sine" and is used to simplify complex numbers, representing the phase shift of the function as 0 degrees. To convert the function to Acos(wot), we can use the trigonometric identity cos(x+y) = cos(x)cos(y) - sin(x)sin(y) and simplify to get Acos(w
noname1
134
i convert it
2e^-j45 = √2/2 - j√2/2
1e^j0 = 1 - j0
adding these up i get
(√2/2 + 1) -j(√2/2)
1.707 - j.707
magnitude = √1.707²+.707² = 1.85
angle = tan^-1(.707/1.707) = 22.5
so i get 1.85cos(wot +22.5)
while the book has the answer
2.798cos(wot-30.36)
nevermind i found my issue forgot to multiply the amplitude
1. What does the term "simplify" mean in this context?
In mathematics, simplifying a function means to write it in a more concise and easily manageable form, without changing its overall meaning or value.
2. What is a sinusoidal function?
A sinusoidal function is a mathematical function that can be represented by a sine or cosine curve. It is commonly used to model periodic phenomena, such as the motion of a pendulum or the changing tides.
3. What is the significance of the number 2 in 2sin(wot+45)?
The number 2 is known as the amplitude of the sinusoidal function, and it represents the maximum distance between the curve and its midline. In this case, the amplitude is 2 units.
4. What is the meaning of "cis" in cis(wot)?
"cis" is a mathematical function that stands for "cosine + i sine" and is used to simplify complex numbers. In this context, it represents the phase shift of the sinusoidal function, which is 0 degrees.
5. Can you explain how to convert this function to Acos(wot)?
To convert the given function to Acos(wot), we can use the trigonometric identity cos(x+y) = cos(x)cos(y) - sin(x)sin(y). Applying this, we get 2sin(wot+45) + cis(wot) = 2cos(45)sin(wot) + cos(wot) - isin(wot). Simplifying further, we get 2sqrt(2)sin(wot) + cos(wot) - isin(wot), which can be written as Acos(wot) with A = sqrt(2).
