Simplify the expression
  • Thread starter frosty8688
frosty8688
126
1. Simplify the derivative
2. [itex] y = \frac{\sqrt{1-x^{2}}}{x}[/itex]
3. [itex] f'(x) = \frac{x*\frac{-2x}{2\sqrt{1-x^{2}}}-\sqrt{1-x^{2}}}{x^{2}}=\frac{-x^{2}-\sqrt{1-x^{2}}}{x^{2}\sqrt{1-x^{2}}}[/itex] I just don't know how to simplify this further.
Answers and Replies
SammyS
Staff Emeritus
1,188
You simplified ##\displaystyle \ \frac{\displaystyle x\frac{-2x}{2\sqrt{1-x^{2}}}-\sqrt{1-x^{2}}}{x^{2}} \ ## incorrectly.
frosty8688
126
So it would be -x[itex]^{2}[/itex] over the square root. So how do I find the second derivative of [itex]\frac{\frac{-x^{2}}{\sqrt{1-x^{2}}}-\sqrt{1-x^{2}}}{x^{2}}[/itex] Do I use the product rule or quotient rule. Which is easier?
SammyS
Staff Emeritus
1,188
Multiply by ##\displaystyle \ \frac{\sqrt{1-x^2}}{\sqrt{1-x^2}} \ .##
frosty8688
126
I already did that and came out with [itex] \frac{-1}{x^{2}\sqrt{1-x^{2}}}[/itex]
frosty8688
126
How do I take the second derivative?
haruspex
Insights Author
7,958
You can use the quotient rule. To differentiate the denominator use the product rule. Alternatively, rewrite it as a product of two terms with negative exponents and just use the product rule.
frosty8688
126
Here is what I have [itex]\frac{\frac{-x}{\sqrt{1-x^{2}}}-\frac{x^{3}}{(1-x^{2})^{3/2}}} x^{2} + \frac{2}{x^{3}}[/itex] The squared on the top is supposed to go with the x on the bottom.
SammyS
Staff Emeritus
1,188
You mean [itex]\displaystyle \ \ \frac{\displaystyle \frac{-x}{\sqrt{1-x^{2}}}-\frac{x^{3}}{(1-x^{2})^{3/2}}} {x^{2}} + \frac{2}{x^{3}}\ \ ?[/itex]
I don't see how that can possibly be correct.
Please show some steps.
frosty8688
126
Here is how I got that answer [itex]\frac{\frac{-2x^{3}}{2(1-x^{2})^{3/2}}}+\frac{2x}{2\sqrt{1-x^{2}}}-\frac{2x}{\sqrt{1-x^{2}}}{x^{2}}-2\frac{\frac{-x^{2}}{\sqrt{1-x^{2}}}}-\sqrt{1-x^{2}}{x^{3}} = \frac{\frac{-2x^{3}}{2(1-x^{2})^{3/2}}}-\frac{x}{\sqrt{1-x^{2}}}{x^{2}}-2\frac{\frac{-x^{2}}{\sqrt{1-x^{2}}}}-\sqrt{1-x^{2}}{x^{3}} = \frac{\frac{-x}{\sqrt{1-x^{2}}}}-\frac{x^{3}}{(1-x^{2})^{3/2}}{x^{2}}-2\frac{\frac{-x^{2}}{\sqrt{1-x^{2}}}}-\sqrt{1-x^{2}}{x^{3}}=\frac{\frac{-x}{\sqrt{1-x^{2}}}}-\frac{x^{3}}{(1-x^{2})^{3/2}}{x^{2}}+\frac{2}{x^{3}}[/itex] That is how I got the answer. The + sign in the first part should be in the numerator and the x^2 should be in the denominator. Same thing with the sign in the second half of the first part and the sqrt should be in the numerator with the x^3 on the bottom, same thing in the second part and third part and last part. Sorry it got messed up.
haruspex
Insights Author
7,958
It doesn't need to be that complicated. Write the first derivative as ##-x^{-2}(1-x^2)^{-\frac 12}## and differentiate using the product rule. Hint: every term in the answer ought to have a factor like ##(1-x^2)^{n-\frac 12}##, some integer n. I'd guess that's how SammyS knew your answer could not be right.
Suggested for: Simplify the expression
