Simplifying Circuit
  • Thread starter Paymemoney
[PLAIN]http://img802.imageshack.us/img802/9172/qns33.png [Broken]
Simplifying the circuit?
Also find the power dissipated in the circuit?
[tex]P=I^2R[/tex]
[tex]V=IR[/tex]
I tired to simply the diagonal by making it parallel with (15+18ohms) and the (10+16ohms) and i get
[tex]R = (\frac{1}{33}+\frac{1}{48}+\frac{1}{16})^{-1} = 8.8ohms
[/tex]
Power of 15ohms is: [tex]1.3^2 * 15 = 25.35W[/tex]
Now how would i find the power dissipated for the rest of the resistors?
P.S
Answers and Replies
SammyS
Staff Emeritus
1,022
I tried to simply the diagonal by making it parallel with (15+18ohms) and the (10+16ohms) and i get
[/tex]
The 48 Ω resistor is in parallel with the (10 Ω + 6 Ω ) combination.
[tex]\displaystyle R_{48,10,6}=\left({{1}\over{48}} + {{1}\over{16}} \right)^{-1}\Omega = 12\ \Omega[/tex]
This combination, [tex]\displaystyle R_{48,10,6}\,,[/tex] is in series with the 18 Ω resistor.
The 15 Ω resistor is in parallel with the combination of the other 4 resistors.
So it will end up being 10ohms when you have simplified everything.
gneill
Mentor
20,906
2,858
Whoa! The 15 and 18 ohm resistors have another branch coming off of their mutual junction; They won't simplify to being simply in parallel.
Now, you *could* get fancy (and complicated) and use something called a Delta-Y transformation on resistors 15, 18, and 48, but it is not necessary if you spot the fact that the 10 and 6 ohm resistors are already alone in series, so that their sum parallels the 48 ohm resistor directly.
SammyS
Staff Emeritus
1,022
Yes. The equivalent resistance for the circuit is 10 Ω.
Related Threads on Simplifying Circuit
  • Last Post
  • Last Post
16K
  • Last Post
  • Last Post
