Simplifying the derivative after using the Product Rule. Help?
In summary: You are very welcome, but you are writing some serious nonsense here. Start with something simpler. What's the derivative of cos(2t)? Explain your answer. And use parentheses like eumyang...The derivative of cos(2t) is -sin(2t). It is the same as the derivative of cos(x) because there is no x in the derivative. The derivative of cos(2t) is -sin(2t). It is the same as the derivative of cos(x) because there is no x in the derivative.Correct!Now, what's the derivative of cos(2t)*sin(6t)?Correct!Now, what's the derivative of cos(2t)*sin(6
Vanessa13
f(x) = (x^3+6)^4 * (x^3+4)^6
f'(x) = (x^3+6)^4*18x^2(x^3+4)^5 + (x^3+4)^6*12x^2(x^3+6)^3
Obviously this expression can be simplified, but I haven't the slightest clue on how to do this.
I would really appreciate the help!
Your derivative is made up of two terms:
18x2(x3+4)5(x3+6)4
and
12x2(x3+4)6(x3+6)3
Obviously, both terms have a factor of 6x2. Both terms also have factors of (x3 + 4) and (x3 + 6).
For each of these factors, bring out the smallest power that is present in both terms.
You should end up with 6x2(x3 + 4)m(x3 + 6)n(something + something else)
18x2(x3+4)5(x3+6)4
and
12x2(x3+4)6(x3+6)3
I'm beginning to understand. If you don't mind, I'm going to show you what I did step by step... Hopefully I do it right.
6x2(x3+4)5(x3+6)3* 3(x3+6) + 12(x3+4) =
6x2(x3+4)5(x3+6)3* (3x3+12+12x3+48) =
6x2(x3+4)5(x3+6)3*(15x3+60)
Did I do the simplifying right?
You have a mistake in the line above, and that affects everything below here.
6x2(x3+4)5(x3+6)3* [3(x3+6) + [STRIKE]12[/STRIKE]2(x3+4)]
Can you take it from here? There's also another mistake below - 3*6 = 18, not 12.
When I was a young student I used to think there was virtue in long formulae like those and if I could handle them it showed I was smart. If anything it showed I wasn't. Took me quite some time to cotton on to the where where where of mathematicians.
I.e. saying instead of your formulae f(x) = 18x2(x3+4)5(x3+6)4 you can say differentiate 18x2u5v4 where u = (x3+4) and v = (x3+6).
Then
f'(x) = 18( 2xu5v4 + 5x2u4u'v4 + 4x2u5v3v') .
You can already see you can take out a factor xu4v3, and further down there may be more simplifications. That way you see what you are doing, the essentials of it. (Of course you do have to remember that the u, v are functions of x so you have to use the chain rule and write not 5u4 but 5u4u' .) Then at the end of the calculation you'll often enough convert back to original variables.
There is no virtue in unnecessarily complicated expressions (and while I am at it, unnecessarily general ones either - you will soon come up across the expression 'without loss of generality'.)
I always make basic errors.
Alright. So with those fixed, this is what my simplified derivative came out to be:
6x2(x3+4)5(x3+6)3(5x3+26)
Better?
Also, THANK YOU!
:) Thank you so much!
I got confused again :(
f(x) = 7cos2tsin6t
I separated them like this: u= 7cos v =2t y =sin6t
u'= -sin v'= 2 y'= cos6
So far my derivative looks like this:
f'(x) = -sin2tsin6t + 7cos2sin6t + 7cos2tcos6
This is the farthest it can be simplified, right?
It probably would have been better if you started a new thread with the new problem. :wink:
f(x) = 7cos2tsin6t
Is the function
f(x) = 7 cos(2t) sin(6t)?
Is the function
That's probably true... Thank you for being my savior! :)
It doesn't have parenthesis around them in my book, so I'm not sure at all... That's why I was so confused.
Is the function
Okay, I did it this way and it makes a lot more sense.
f'(x)= -sin2tsin6t + 7cos2tcos6t
I think that's all I can do with it, right?
Simplification aside, that's not the derivative of 7*cos(2t)*sin(6t). Just like the derivative of cos(2t) is not -sin(2t). You have to use the chain rule.
I see that now.
Here goes, third times a charm (hopefully)...
v' = -7sin2sin6t + 7cos2tcos6 + 0 * cos2tsin6t
= -7sin2sin6t + 7cos2tcos6 (then you take out a 7, right?)
v' = 7(-sin2sin6t)(cos2tcos6)
I'm not sure if I'm still supposed to be adding them [(-sin2sin6t) + (cos2tcos6)] or not, but in the example earlier, getting rid of common things also got rid of the addition...
Am I right now?
(Thank you for helping :] )
Vanessa13 said:
I see that now.
Am I right now?
You are very welcome, but you are writing some serious nonsense here. Start with something simpler. What's the derivative of cos(2t)? Explain your answer. And use parentheses like eumyang suggested.
I feel really ignorant now.
derivative of cos(2t) = -2sin(2t)
derivative of sin(6t) = 6cos(6t)
derivative of 7 = 0
derivative of 7 = 0
That's great! Now use the product rule on 7 cos(2t) sin(6t). There won't be anything like sin(2) in there, will there?
v' = -2sin(2t)sin(6t)*7 + cos(2t)*6cos(6t)*7 + 0
v' = -14sin(2t)sin(6t) + 42cos(2t)cos(6t) [Took 14 out...]
v' = 14(-sin(2t)sin(6t)) + 3(cos(2t)cos(6t)) [Do I continue to add them?]
No. I think you should leave it as that. It's about as simple as it's going to get.
Thank you.
Would you mind if I ever messaged you with a question now and then?
As you can probably tell, Calculus isn't exactly my strong suit.
Vanessa13 said:
Thank you.
You can message me if you post the question and you feel you aren't getting the answer you want after a while. Send me link to the post. Don't send the question through a message. Give other people a chance to help. I'm not around 24/7.
In the original equation you probably meant f(t) not f(x).
Get inside it. It's not an arbitrary rule you are forced to remember and feel stupid if you don't.
Draw any old curve graph and call it f(t) .
Remember what 'function' means and example exercises probably done to familarise you right at the start.
f(2t) gets to the height that f(t) does in half as much time. It is increasing/decreasing twice as fast.
f'(2t) = 2 f'(t).
( Same idea are f'(kt) = k f'(t)
f'(g(t)) = f'(g(t))g'(t) )
1. What is the Product Rule?
The Product Rule is a formula used in calculus to find the derivative of a product of two functions. It states that the derivative of the product of two functions is equal to the first function multiplied by the derivative of the second function, plus the second function multiplied by the derivative of the first function.
2. Why do we need to simplify the derivative after using the Product Rule?
After using the Product Rule, the resulting derivative may be in a complex or expanded form. Simplifying the derivative allows us to express it in a more concise and understandable form.
3. How do we simplify the derivative after using the Product Rule?
To simplify the derivative, we use algebraic techniques such as combining like terms, factoring, and distributing. We also identify any common factors and simplify fractions if necessary.
4. Can I skip simplifying the derivative and just leave it in its expanded form?
Technically, you can leave the derivative in its expanded form, but it may be more difficult to interpret and work with. It is always recommended to simplify the derivative for a clearer understanding of the result.
5. Are there any common mistakes to avoid when simplifying the derivative after using the Product Rule?
One common mistake is forgetting to distribute the derivative to both functions in the product. Another mistake is not combining like terms or factoring properly. It is important to double check your work and make sure all steps are correctly applied.
