Length Contraction & Simultaneity: Train-and-Platform Experiment
In summary: The observer you query is obliged to agree with the stationary observer that events A and B happened at the same place in the stationary observer's frame.
mrsmitten
I was reading about (The train-and-platform thought experiment) from https://en.wikipedia.org/wiki/Relativity_of_simultaneity
and was wondering a couple of things.
1.) Would the observer on the train agree with the stationary observer that event A and B happen at the same place in the stationary observer's frame?
2.) Would they both agree that the distance between event A and B is the same?
3.) Would the distance between A and B be just the length of the train?
In the train/platform experiment, we have two lightning strike events and (in the simplest form of the experiment) one "light from both flashes reaches both observers' eyes at the moment that they're even with one another" event. None of the three happen at the same place according to any observer, nor could they as none of them are time-like separated. So which of these are the ones that you are calling "event A" and "event B", and did you mean "at the same time" above?
Nope
(In the simplest form of the experiment) I think both observers would agree that one lightning strike hit the front of the train and the other hit the back.
let's say that "event A" is the moment that the moving observer sees the lightning strike the front of the train and "event B" is the moment when the moving observer sees the lightning hit the back of the train. If the moving observer marks the points in the stationary observer's frame at which he sees "event A", let's call it X1 and at "event B" X2.
Would the stationary observer agree that events A and B happened at X1 and X2?
You need to be careful with that word "sees" - an observer sees something when light emitted from it reaches his eyes, and he calculates when it happened by subtracting the light travel time from the time the light hits his eyes (he can read this time from his wristwatch). In the train experiment as it is usually set up there is a point in spacetime where the platform and train observer are colocated as the one passes by the other. That's one point in spacetime so it is a single event; we can call it event O if we want to name it.
The light from both lightning flashes hits both observers' eyes at this point in spacetime, so we say that both observers see both flashes at event O. Of course event O is different than the other two events in the thought experiment, namely the two lightning flashes striking the rails at two different places.
Agreed, I think the wording in my last statement was bad. I will try and think of a better way to word it.
But the principle is I want to know if both observers agree on the position X1 (in the stationary observer's frame) of the front of the train when it's struck, and the position of the back of the train X2 when it's struck.
If you are ask about "position X1 (in the stationary observer's frame)" then it does not matter what observer you question. You've chosen a frame and that's the end of the story. From the way you pose the question, the observer you query is obliged to transform into the stationary observer's frame before providing his answer.
All observers agree that the lightning bolt blasted the front of the train and a charred a spot on the tracks at the same place and time that the front of the train passed that spot on the tracks.
Event A is the lightning striking the front of the train. Yes, both observers agree that lightning struck the front of the train, at the front of the train.
Likewise Event B is lightning striking the rear of the train, so both observers agree that lightning struck the rear of the train, at the rear of the train.
Of course, Events A and B don't occur at the same place as each other!
No.
Yes.
Both observers would agree on the coordinates of the two strikes both in their own frame and in the other's frame. They just would not agree on the distance between the two strikes, (i.e., the differences in the coordinates, even though they are using identical rulers in their own frames). If the guy on the train receives the flashes at the same time, the guy on the ground would not. He would conclude that one strike happened first, and the other strike happened afterwards. And, in his frame of reference, he would be correct.
Likes jbriggs444
1. What is length contraction?
Length contraction is a concept in Einstein's theory of special relativity that states an object in motion will appear shorter in length when observed from a stationary frame of reference.
2. How does length contraction affect the measurement of an object's length?
According to special relativity, the measured length of an object will decrease as its velocity increases. This effect is only noticeable at speeds approaching the speed of light.
3. How does the train-and-platform experiment demonstrate length contraction?
The train-and-platform experiment involves two observers, one on a moving train and one on a stationary platform, measuring the length of the train as it passes by. The observer on the platform will measure the train to be shorter than the observer on the train due to their different frames of reference.
4. What is the relationship between length contraction and time dilation?
Length contraction and time dilation are both consequences of Einstein's theory of special relativity. Length contraction refers to the shortening of an object in motion, while time dilation refers to the slowing down of time for an object in motion relative to a stationary observer.
5. Can length contraction be observed in everyday life?
No, length contraction is only noticeable at speeds close to the speed of light, which is much faster than any speed humans are capable of achieving in everyday life. However, it is a well-established phenomenon that has been observed in experiments with particles traveling at high speeds.
