Homework Help: Simultaneous equations
  1. Jan 25, 2012 #1
    How do yo solve simultaneos equations?
    2. Relevant equations
    Am I right ?
    3. The attempt at a solution
    y = x2 – 5x + 5 question a
    5x + 3y = 30. question b
    Find location of points collide?
    Add a+b
    x2 + 2y -25=0
    quadratic formula use
    x= -2+ square root(2^2-(4x1x(-25))/2 x = 4.09901
    or
    x= -2 - square root(2^2-(4x1x(-25))/2 x=-6.09
    subsitue y etc
  3. Jan 25, 2012 #2
    berkeman
    Staff: Mentor
    Looks like you are on the right track...
  4. Jan 25, 2012 #3
    Cheerio
  5. Jan 25, 2012 #4
    eumyang
    I would use substitution. You already have equation a solved for y. Plug it into equation b:
    5x + 3y = 30
    5x + 3(x2 – 5x + 5) = 30
    ... and so on.
  6. Jan 25, 2012 #5
    NascentOxygen
    Staff: Mentor
    Errrm, if eumyang is on the right track, then I'll eat my hat!
    ... and I'll post the video of it on youtube.
  7. Jan 25, 2012 #6
    SammyS
    Staff Emeritus
    You can't use the quadratic formula on x2 + 2y -25=0, because it has two different variables in it.
    B.T.W: Yesterday, Mark44 pointed out to you that you should not use the lower case letter, x, to indicate multiplication.
  8. Jan 26, 2012 #7
    Hey ladies ;) + gentleman :)
    Now you have "REALLY" lost me.
    I went with eumyang- subsituations and this is what I have done.
    NB: Allright I WILL USE . FOR MULTIPLY NOW
    Ok, lets start
    1)
    y = x^2 – 5x + 5 question a
    Answer;
    5x + 3(x^2 – 5x + 5) = 30
    5x+ 15x^2 -15x+15=30
    15x^2-10x+15=30
    15x^2-10x -15 = 30
    5(3x^2 -2x -3) = 30
    use formula
    x= 2 + sqrt{40} / 6
    x= 1.3874
    or
    x=2 - sqrt{40} / 6
    x= -0.72075
    Is this the right directions?
  9. Jan 26, 2012 #8
    SammyS
    Staff Emeritus
    The coefficient of the x2 term is 3, not 15.
    Once you get a solution for x, you should go back to an original equation to find y. To check your answer for the pair x & y, you should then plug those values into the other original equation.
  10. Jan 27, 2012 #9
    NascentOxygen
    Staff: Mentor
    CORRECTION: I intended to write
  11. Jan 27, 2012 #10
    NascentOxygen
    Staff: Mentor
    You must make the right hand side = 0 before using the quadratic formula.
    Taking as an example: 15x^2 - 10x - 15 = 30
    Make RHS=0:
    15x^2 - 10x - 15 - 30 = 30 - 30
    x = (10 ± sqrt(100 + 4•15•45)) / 30
Loading...
