Simultaneous Equations
FeDeX_LaTeX
Main Question or Discussion Point
The problem:
"[tex]xy + yz + zx = 12[/tex]
[tex]xyz = 2 + x + y + z[/tex]
Find a solution of the above simultaneous equations, in which all of x, y and z are positive, and prove that it is the only such solution.
Show that a solution exists in which x, y and z are real and distinct."
I haven't really made much progress on this problem. I divided the first equation by the second and got;
[tex]\frac{1}{x} + \frac{1}{y} + \frac{1}{z} = \frac{12}{2 + x + y + z}[/tex]
or
[tex]2 + x + y + z = \frac{12}{\frac{1}{x} + \frac{1}{y} + \frac{1}{z}}[/tex]
if we do this:
[tex]\frac{2 + x + y + z}{4} = \frac{3}{\frac{1}{x} + \frac{1}{y} + \frac{1}{z}}[/tex]
I notice that the LHS is the arithmetic mean of {2, x, y, z} and the RHS is the harmonic mean of {x, y, z}. They are equal iff x = y = z = 2, so one solution is x = 2, y = 2, z = 2. BUT it appears that they want x, y and z to be distinct.
Can anyone help me here?
Thanks.
EDIT:
Wait... on second thought, what I wrote is wrong. The two sets {2,x,y,z} and {x,y,z} aren't identical. Looks like I am back to square one.
Answers and Replies
The problem:
if we do this:
Thanks.
EDIT:
Since the solution is unique, you can try to make the problem simple by adding a relationship between x,y and z and see if the problem can still be solved. perhaps you may try x,y,z form an arithmetic sequence, etc. What makes you think z,y,z must be different? Looks like a valid solution, i.e. the one in which x thru z are each positive. In the second part, a negative number could be included.
pwsnafu
85
There are two different problems here, and you are conflating them
The problem:
You want the unique positive solution. It is obvious that x=y=z=2 is the solution because you can substitute the values in the original. What you need to show is that unique implies symmetric.
The only positive solution is symmetric, so if you want distinct, at least one must be negative.
Related Threads on Simultaneous Equations
  • Last Post
  • Last Post
  • Last Post
  • Last Post
23K
