• Support PF! Buy your school textbooks, materials and every day products Here!
Sin function
  • Thread starter ehrenfest
[SOLVED] sin function
1. Homework Statement
My complex analysis book says, "from calculus, [itex]\sin \theta \leq \theta[/itex] for [itex]0 \leq \theta \leq \pi/2 [/itex]." Could someone please give me a better reason why that is true?
2. Homework Equations
3. The Attempt at a Solution
Answers and Replies
1,631
well, the only way i know how to prove that [tex]|sin(x)|<|x|[/tex] is with the aid of geometry. YOu need to construct a circle with radius R=1, and denote wit OAB a triangle, and with AB the arch. Denote also by x the angle that the two sides, the radiuses of the circle enclose. And you will see the validity of this. This is true only when the angle is measured in radians. Because also remember that a portion of the arch of the circle, call it acrAB is actually the measure of the angle in radians, if we draw two lines that pass through the two points in the circle A,B.
morphism
2,013
You could also consider the function f(x)=x-sin(x) and it's derivative.
1,996
Gib Z
3,344
It should also be clear if you use the series definition for sine.
631
Drawing their graphs will also make it clear.
tiny-tim
25,789
249
… chord-length < arc-length …
Hi ehrenfest! :smile:
The intuitive explanation is: 2sinx = chord-length (a straight line :smile: ), which is less than 2x = arc-length (not a straight line :frown: ), for 2x < π.
(This is sutupidmath's explanation, of course, with the details left out.)
1,996
Its not clear. For that to be true, you need to know that the sum of all the terms after the first is negative and has magnitude less than the first term in the series. Why is that true?
Neither to me...
Gib Z
3,344
My bad. The things you stated there are sometimes used when deriving the series in the first place and showing the Taylor Remainder term goes to zero, but not always. I wrongly assumed you learned it the same way I did.
Related Threads for: Sin function
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
