Exploring the Possibility of Siphons Working in a Vacuum
  • Thread starter moronthat
  • Tags
    Vacuum
In summary, the Oxford dictionary is changing the definition of a siphon to remove the requirement of air pressure. However, a siphon still relies on atmospheric pressure for its maximum height, which is limited to 9.8m. In a vacuum, the maximum loop height would be 0. The liquid used in a siphon does not affect its mechanism, but it will still have a finite vapor pressure. This topic is also being discussed in another forum.
moronthat
The Oxford dictionary is about to change its definition of a siphon to remove the reference to air pressure as being required. Will a siphon work in a vacuum?
No the water will boil.
Although a siphon doesn't run on air pressure, air pressure still has an effect.
The main limit on a siphon is that the head of water (the distance between the surface of the upper level and the top of the siphon hoop) can't be more than the height of a column of water supported by atmopsheric pressure (ie 9.8m)
At lower pressures the maximum height of the loop will decrease and in vacuum it reaches 0
I didn't say the liquid was water.
Doesn't matter - it will still have a finite vapour pressure.
The mechanism of a siphon isn't air pressure - but you can't have a loop height more than the maximum column of the liquid that can be supported by air pressure.
1. How does a siphon work in a vacuum?
A siphon works by creating a pressure difference between two points in a liquid. In a vacuum, there is no atmospheric pressure to push the liquid down, so the siphon would not work in the traditional sense.
2. Is it possible for a siphon to work in a vacuum?
While a traditional siphon may not work in a vacuum, there are other types of siphons, such as a vapor pressure siphon, that can function in a vacuum by utilizing the vapor pressure of a liquid instead of atmospheric pressure.
3. What experiments have been done to test the possibility of siphons working in a vacuum?
Several experiments have been conducted, including one by Italian scientist Evangelista Torricelli in the 17th century. He found that a siphon could not function in a vacuum, but it was later discovered that his experiment did not take into account the vapor pressure of the liquid.
4. What are the potential applications of a siphon in a vacuum?
If a siphon were to work in a vacuum, it could potentially be used in scientific experiments and industrial processes that require a liquid to be moved in a vacuum environment. It could also have applications in space exploration and technology.
5. Are there any current technologies or methods that utilize siphons in a vacuum?
While there are no known technologies that use traditional siphons in a vacuum, there are technologies that use principles similar to siphoning, such as capillary action, to move liquids in a vacuum.
  • Classical Physics
  • Mechanical Engineering
  • Classical Physics
  • Classical Physics
  • Classical Physics
