What causes the size of a cavity to change when a metal plate is heated?
In summary, the metal plate with a circular hole/cavity in it will get smaller as the hole/cavity gets bigger.
sodaboy7
81
There's a metal plate with a circular hole/cavity in it. Consider its width negligible. Now the plate is uniformly heated. Textbook says that size of hole/cavity increases along with the dimensions of the plate. But my intuition says dimensions of cavity should increase and size of hole/cavity should decrease. Its just like the "expanding" metal plate is "pushing" the metal inwards the cavity/hole making it smaller. Need Explanation to this.
I think you have to say the hole gets bigger. There is a standard school demonstration of expansion called a 'ball and ring'. You heat up the ball and, not surprisingly, it does not fit through the ring.
Now you heat up the ring and the ball goes through.
Metal tyres for cartwheels and metal rims for railway wheels are heated to make them expand to fit over the wheel. When they are cooled they tighten onto the wheel.
Imagine a circular metal plate on which you have drawn a chalk circle about half way between the centre and the rim.
Heat the plate. Does the chalk circle expand or contract?
Now cut out a hole in the plate marked out by the chalk but with the chalk line just visible.
Heat the plate. Does the chalk circle expand? Does the hole?
The metal on the edge of the hole expands. This causes the ring to expand.
Think of it like this. You have a bunch of metal molecules. Think of them like balls. These balls are placed in a ring and then super glued together. As the balls expand they have to move outwards. Away from the center because it's the only way they can expand and stay connected. Now on a disk with a hole in the center. If the Disk is large enough the circumferal expansion will be greater than the radial expansion. This can lead to the warping of the disk introducing a wave pattern into the plane of the disk. This is what happens in brake rotors when they get warped.
Thank you, that's the explanation I needed.
1. What is the size of the cavity on expansion?
The size of the cavity on expansion varies depending on the material and conditions of expansion. It can range from a few millimeters to several centimeters.
2. How is the size of the cavity on expansion determined?
The size of the cavity on expansion is determined by factors such as the type of material, the temperature and pressure at which expansion occurs, and the rate of expansion. These factors can be controlled and adjusted to achieve the desired cavity size.
3. Are there any limitations on the size of the cavity on expansion?
Yes, there are limitations on the size of the cavity on expansion. These limitations are determined by the properties of the material being expanded and the conditions of expansion. It is important to carefully consider these limitations in order to avoid any potential problems.
4. Can the size of the cavity on expansion be controlled?
Yes, the size of the cavity on expansion can be controlled to some extent. By adjusting the factors mentioned earlier, such as temperature and pressure, the size of the cavity can be controlled to achieve the desired result. However, there may be some limitations to this control depending on the material being expanded.
5. How does the size of the cavity on expansion affect the overall expansion process?
The size of the cavity on expansion can greatly affect the overall expansion process. A larger cavity can result in more expansion and a stronger final product, while a smaller cavity can result in less expansion and a weaker final product. It is important to carefully consider the desired size of the cavity in relation to the intended use of the expanded material.
12K
  • Thermodynamics
  • Nuclear Engineering
  • Mechanical Engineering
