Does the velocity of a skateboard affect the impact of a flat-landing drop?
In summary, the conversation is about the impact of an object landing on a horizontal surface and whether the velocity of the object affects the impact. The conclusion is that while the horizontal velocity does not play a role, the vertical velocity and the placement of the object's center of mass can affect the amount of rotation and potentially the impact. Air resistance would only make a noticeable difference at very high speeds. The amount of force from the impact would also depend on how the object lands.
Neeson
I've been having a bit of a discussion with a friend lately, about an object dropping off a horizontal surface, falling a certain amount, and then landing on another horizontal surface.
The question is whether the impact of landing on the horizontal surface, will be affected by the velocity of the object.
It started about flat-landing drops on a skateboard. Do you land as hard going fast as you do going slow? The size of drop would be between in the range of 4-10 feet.
From my understanding, the velocity will make no difference, as an object is always affected by gravity in the same way, ie accelerating downward vertically at 9.8m/s. The horizontal velocity would not factor in, as when you land you would continue moving at the same velocity as take-off due to Newtons law, thus there is no force dissipated here. Sorry, my ability to explain physics is quite limited!
Could there be anything that I am not taking into account? I am assuming air resistance, would be negligible at these speeds. Is this correct?
Any clarification and explanation of this matter would be highly welcomed.
Everything is right, but there is one factor to which the speed makes a difference.
When you leave the edge, the rear wheels are supported for a while after the front ones went over. If you aren't careful about placing your CM neatly over the rear wheels, you'll pick up a bit of a rotation going over. When you are moving faster, you spend less time in this half-suspended state, and so pick up less rotation, giving you better odds of safe landing.
The vertical velocity with which you hit the ground, however, does not change. It is completely independent from horizontal motion.
Air resistance would play a role if you were going fast enough, but that'd be something in the neighborhood of 100mph to make any sort of a noticeable difference. I'm pretty sure you'd have other problems if you tried to go that fast on the skateboard.
Will this increase the amount of force that you land with though? It's not the odds of landing that I'm looking for (I'm assuming a perfect landing), just the amount of impact.
If you land on the wheels in both cases, no difference. If you land on your face, it's going to depend on many things.
I can confirm that the velocity of a skateboard will not affect the impact of a flat-landing drop. This is because, as you mentioned, objects are always affected by gravity in the same way and the horizontal velocity of the skateboard will not factor in when landing. This is due to the principle of inertia, where an object will continue moving at a constant velocity unless acted upon by an external force. In this case, the skateboarder's body and the skateboard will continue moving at the same velocity as before the drop, resulting in the same impact regardless of the initial velocity.
Additionally, air resistance is a factor that can affect the velocity and acceleration of an object, but as you mentioned, it would be negligible at the speeds of a skateboard drop. Air resistance becomes more significant at higher speeds and larger objects, such as a skydiver or a car.
It is important to note that the impact of a flat-landing drop can still be affected by other factors such as the surface material and angle of landing. For example, landing on a softer surface or at a steeper angle may result in a lesser impact compared to landing on a hard surface or at a shallow angle.
In summary, the velocity of a skateboard will not affect the impact of a flat-landing drop due to the principles of gravity and inertia. Other factors such as surface material and angle of landing may have a greater impact on the overall force experienced by the skateboarder.
1. How does a skateboard drop to flat?
A skateboard drops to flat when the rider jumps off the board, causing it to fall to the ground and make contact with the surface at a perpendicular angle.
2. What happens to the skateboard when it drops to flat?
When a skateboard drops to flat, it experiences a sudden impact force as it makes contact with the ground. This can cause the wheels to compress and absorb the impact, while the deck may flex or even break depending on the force of the drop.
3. Is dropping a skateboard to flat damaging to the board?
Dropping a skateboard to flat can cause damage to the board over time, especially if done frequently or from a high height. It can lead to cracks or breaks in the deck, and can also affect the integrity of the trucks and wheels.
4. Why do skateboarders drop their boards to flat?
Skateboarders may drop their boards to flat as a way to perform tricks and stunts, such as landing from a jump or performing a drop-in from a high surface. It can also be a way to test the durability of the board and push its limits.
5. What are some safety precautions to take when dropping a skateboard to flat?
When dropping a skateboard to flat, it is important to wear proper protective gear such as a helmet, knee pads, and elbow pads. It is also important to start with smaller drops and gradually increase the height to avoid injury. Proper technique and landing on the bolts of the board can also help reduce the impact on the board and the rider's body.
  • Other Physics Topics
  • Mechanical Engineering
