• Support PF! Buy your school textbooks, materials and every day products Here!
Sketch Complex Regions
  • Thread starter alexcc11
Sketch the following regions and state the interior and the closure:
a) |z-2+i|≤1
b) Im(z)>1
z=x+iy
a) z=x+iy so |x+iy-2+i|-> |(x-2)+i(y+1)|≤1
So (x-2)2+(y+1)2≤1
So it would just be a circle on the real plane? And the interior would be the equation with < instead of ≤ right? I'm not sure how to write the closure though.
b)Im(z)= y so it would be a straight line at y=1 on the real plane and there is no interior or closure since it is an open set right?
Answers and Replies
SammyS
Staff Emeritus
953
a) |z-2+i|≤1
b) Im(z)>1
z=x+iy
So (x-2)2+(y+1)2≤1
What is the definition of the closure of a set?
For (b):
y = 1 is the solution to Im(z) = 1, not Im(z) > 1 .
My book says that a set is closed if it contains all boundary points, but Im(z)>1 is open, so there is no closure. Do you know if the other parts are correct, referring to graphing them?
SammyS
Staff Emeritus
953
You are confusing a closed set with the closure of a set.
How do you show the closure of a set if it's an open set? For part a, would the showing the closure just be writing the equation out since it's a closed set?
SammyS
Staff Emeritus
953
First of all, does your book give the definition of the closure of a set?
Secondly, your answer to (a) was correct, since the closure of a closed set is the set itself.
The book just says Ω is closed if Ω <=> C'Ω where Ω in C'Ω has a line above it and = {zεC: each neighborhood = D_ε(z) intersects Ω
An example is: E={zεC: .5≤|z|<1}
E_1= {zεC :|z|=1/2}
E_2= {zεC :|z|=1}
E_3= {zεC : .5<|z|<1}
The closure is:E_1 [itex]\bigcup[/itex]E_2 [itex]\bigcup[/itex]E_3
but I don't know who to write that with these problems.
SammyS
Staff Emeritus
953
E_1= {zεC :|z|=1/2}
E_2= {zεC :|z|=1}
Nothing there gives a definition of the closure of a set.
The given example can be helpful.
The set E itself is neither closed nor open.
Notice that ##\ E_3\ ## is open and is the interior of ##\ E\ .##
Furthermore, ##\ E_1\cup E_2\ ## is the boundary of ##\ E\ .##
One can also say that ##\ E\cup E_2\ ## is closed. It's also the closure of ##\ E\ .##
The closure of a set ##\ X\ ## can be thought of as the "smallest" closed set which contains ##\ X\ .##
that really helps! Thanks a lot!
Related Threads for: Sketch Complex Regions
  • Last Post
  • Last Post
  • Last Post
