Skiing up a Hill
  • Thread starter Hypnos_16
A 69.7-kg skier coasts up a snow-covered hill that makes an angle of 26.8° with the horizontal. The initial speed of the skier is 6.16 m/s. After coasting 1.98 m up the slope, the skier has a speed of 3.95 m/s. Calculate the work done by the kinetic frictional force that acts on the skis.
m = 69.7
Theta = 26.8 degrees
v1 = 6.16 m/s
d = 1.98m
v2 = 3.95 m/s
I've found the total work done by using Wnc = Ef - Ei
but that gives me the wok of all the forces and i don't know how to pinpoint just the force done by friction
∑W = Ef - Ei
∑W = (1/2mv^2) + (mgh) - (1/2mv^2) + (mgh)
∑W = (34.9)(3.95^2) + (69.7)(9.81)(1.98) - (34.9)(6.16^2) + (69.7)(9.81)(0)
∑W = (544) + (1353.8) - (1324) + (0)
∑W = 1897.8 - 1324
∑W = 573.8 J
Answers and Replies
tiny-tim
25,836
251
Hi Hypnos_16! :smile:
(have a theta: θ and try using the X2 and X2 icons just above the Reply box :wink:)
The only forces (apart from gravity, which you've included in your E) are the normal force, N, which does no work, and the https://www.physicsforums.com/library.php?do=view_item&itemid=39"
so all the https://www.physicsforums.com/library.php?do=view_item&itemid=75" (in this case) is by friction! :smile:
so what you're saying is i already found the answer?
tiny-tim
25,836
251
he he! :biggrin:
life sometimes is that simple! :smile:
(oh, they might want you to say whether the work done is positive or negative)
But wait, wouldn't i need to use the sin 26.8 degrees for the force of gravity since it's down a hill?!
tiny-tim
25,836
251
You already used the work done by gravity when you calculated the energy …
you included mgh in your E …
in coordinates, that's (x,y,h).(0,0,g), ie minus distance "dot" force …
https://www.physicsforums.com/library.php?do=view_item&itemid=269" by that force …
in the work-energy equation, you can either include gravity in the PE (on one side), or in the work done (on the other side), but not both! :wink:
Related Threads on Skiing up a Hill
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
