Skydiver falling (i am stuck)
In summary, the problem involves a skydiver who jumps out of an airplane at an altitude of 1000.0 m and opens a parachute at some altitude. The total retarding force on the skydiver is constant at 50.0 N with the parachute closed and at 3600.0 N with the parachute open. The goal is to determine the altitude at which the parachute should be opened so that the skydiver lands with a velocity of 5.00 m/s on the ground. The solution involves finding the acceleration for each part of the motion, setting up equations for the two parts and solving for the unknown distance. The equations involve the initial and final speed, as well as the total distance. Another approach
3dsmax
"An 80.0 kg skydiver (initially at rest) jumps out or an airplane at an altitude of 1000.0 m and opens the parachute at some altitude. Assuming that the totalretarding force on the skydiver is constant at 50.0 N with the parachute closed and the constant at 3600.0 N with the parachute open, at what altitude should the skydiver open the parachute so that he lands with a velocity of 5.00 m/s on the ground?"
Quite a mouth full.
Vf^2 = Vi^2 + 2ax
Sigma F= MA
Okay I am really kinda stuck on this one.
I tried figuring out the acceleration by doing:
784.8 N -3600N = 80 kg(a)
but that yields an acceleration of -35 m/s^2, And that can't be right.
I also drew a free body diagram but i can't post that up.
I know that the correct answer is 207 m because the teacher gave that to us.
Can anyone help me?
Why not?
But that's just the acceleration during the second part of the motion (after the chute opens). What about the first part of the motion?
Well i thought of that but i didn't seem to get me anywhere.
So then if i do do this:
784.5 N - 50 N = 80 kg (a)
then i get an acceleration of :9.185 m/s^2
but where would i go with that?
Find the acceleration for each part of the motion (youre on the right track). Then you need to find the right distance for each part of the motion knowing that the total distance is 1000.0m
Set up equations for the two parts of the motion and see what you can figure out. You know the initial and final speed, and the total distance.
ok so then if i use my equation ^^^.
and do 5m/s^2= 0 + 2(-35.2 m/s^2)(x)
i get x = to -0.355 m
and 5m/s^2 = 0 + 2(9.2m/s^2)(x)
i get 1.36 m
and that can't be right. What am i doing wrong?
Oh and to the website designers it would be a nice plus to have a exponent button.
It starts at rest, accelerates positively to a middle velocity, and then decelerates back to 5m/s. Eliminating should get rid of the intermediate velocity, though
I am not really helped out by your response could you give me an example? or a clue
There is. If you want to write m/s2 you write m/s[ sup ]2[/ sup ] (without the spaces in the square brackets.)
Your top equation should start off (5m/s)^2 - vMIDDLE(^2)
Your bottom equation should start off (vMIDDLE)^2 - (0m/s)^2
And make sure you don't use the same distance in both equations
yes but that would give me:
5m/s2 - vmiddle2 = 0 + 2(-35.2 m/s2)(x)
which gives me to variables to figure out. And i am only in honors physics in 11th grade so I don't know how to do that.
You need as many equations as you have unknowns. I count 3 equations with 3 unknowns. You don't know d1, d2, or vmiddle. But you can eliminate vmiddle and easily write d2 in terms of d1 because they sum up to 1000 (think of an angle and its complement). After eliminating, you should be able to substitute and get either d1 or d2. Then you just subtract that from 1000
you know what you are saying is slapping on the bell but not ringing it.
My parents want me to get some sleep can you just set up the equation for me, cause i am still lost. Like what do i do to find the d2?
have you learned energy yet? this problem could be very simply solved by energy.
just look at the work done by each force. Assuming that the person doesn't go back upward, you can set up an equation.
oh i completely forgot about on of the equations that the teacher gave us:
(sigma)work = 1/2mvf2-1/2mvi2
I think that the right side of the equation cancels out because there is no vi. But how do i do the work part?
well, so you have the work.
and Work=Force * Distance... Now, assuming that the first net force acts over a distance of x, what would the work done by the first and second force be (in terms of x) (be very careful about the sign of the work)? together, what is the equation that can solve the problem?
thank you i will try it
What is the cause of a skydiver getting stuck while falling?
The most common cause of a skydiver getting stuck while falling is their parachute malfunctioning. This can happen due to a variety of reasons such as improper packing, equipment failure, or user error.
What should a skydiver do if they are stuck while falling?
If a skydiver finds themselves stuck while falling, they should first try to assess the situation and determine the cause. If the issue is with their parachute, they should attempt to deploy their reserve parachute. If they are unable to do so, they should then try to release their main parachute and deploy their reserve. If all else fails, they should try to steer towards a safe landing spot and brace for impact.
Can a skydiver survive a fall if they are stuck?
The chances of survival for a skydiver who is stuck while falling depend on the specific situation and the altitude at which they are stuck. If the skydiver is able to deploy their reserve parachute, they have a much higher chance of survival. However, if they are unable to deploy either parachute, the chances of survival are significantly lower.
How common is it for a skydiver to get stuck while falling?
Skydiver getting stuck while falling is a relatively rare occurrence. The majority of skydiving accidents are caused by human error and not equipment malfunctions. However, it is always essential for skydivers to be prepared for any situation and to undergo proper training and safety procedures.
What safety precautions can a skydiver take to prevent getting stuck while falling?
To prevent getting stuck while falling, skydivers should always properly pack their parachutes and thoroughly check their equipment before every jump. They should also undergo regular safety training and follow all safety protocols. In case of an emergency, skydivers should always have a backup plan and be prepared to handle any situation that may arise.
10K
