• Support PF! Buy your school textbooks, materials and every day products Here!
Sliding block
  • Thread starter jti3066
A 5.86 kg block located on a horizontal frictionless floor is pulled by a cord that exerts a force F = 10.00 N at an angle = 35.0° above the horizontal (x-axis). What is the speed of the block 3.70 seconds after it starts moving?
Fcos() - ma = 0
Fsin() - mg = 0
V_f = V_0 + at (V_0 = 0)
Since the first two equations are equal to zero I set them equal to each other and then solved for acceleration. I then used this in the last equation to solve for V_f. Apparently I am doing something wrong because I am not getting the correct answer.
Answers and Replies
rl.bhat
4,433
What is the value of the acceleration? Will you show your calculations?
Fcos() - ma = 0
Fsin() - mg = 0
so setting these two equations together and inputting given data:
10cos(35) - 5.86(a) = 10sin(35) -5.86(9.81)
8.192 - 5.86(a) = 5.736 - 57.487
-5.86(a) = 5.736 - 57.487 - 8.192
-5.86(a) = -59.943
a = 10.22918089 m/s^2
Now to solve for V_f (final velocity)
V_f = V_0 + at
V_f = 0 + 10.23(3.7) = 37.84 m/s
FAIL!!!!!! This is the wrong answer
rl.bhat
4,433
This step is wrong. There is no acceleration in the vertical direction because the action and reaction are equal and opposite. Hence
F*cos(θ) = ma
Ok....got it
This always holds true correct, except when the object is inclined/declined
here are the proper calculations:
10cos(35) = 5.86(a)
a = 1.39 m/s^2
V_f = 0 + 1.39(3.7) = 5.17 m/s
correct answer
Thanks a bunch
Related Threads on Sliding block
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
19K
  • Last Post
  • Last Post
  • Last Post
