• Support PF! Buy your school textbooks, materials and every day products Here!
Sliding on a water slide
  • Thread starter vxr
vxr
25
Homework Statement:
A person of mass ##m = 75## kg slides a distance ##d = 5## m on a straight water slide, dropping through a vertical height ##h = 25## m. Determine the mechanical work done by gravity on the person? What is the height h if the mechanical work done by the gravity is ##W = 2010## J?
Relevant Equations:
Probably some of these:
##E = mgh + \frac{1}{2} mv^2##
##W = \Delta \frac{1}{2} mv^2##
I don't really understand if the initial horizontal velocity is 0? Or do I assume it's some constant? Putting aside vertical velocity.
Also how should the "mechanical work done by gravity" be calculated? Is it just ##W = \frac{1}{2}mv^2_{final} - \frac{1}{2}mv^2_{initial}##
Answers and Replies
kuruman
Insights Author
2,425
The mechanical work done by gravity is ##m\vec g \cdot \vec d## where ##\vec d ## is the displacement vector.
BvU
2019 Award
13,360
3,164
What does ##d=5## m mean ? in the context of dropping through 25 m !
vxr
25
I am really unsure. I tried to draw it and I came up with this:
243963
kuruman
Insights Author
2,425
The statement of the problem makes one believe that the slide is an inclined plane of 5 m hypotenuse and vertical side 25 m. This is impossible unless the vertical side is something else, 2.5 m perhaps?
Perhaps it should have said
A person of mass m=75 kg slides a horizontal distance d=5 m on a straight water slide, while dropping through a vertical height h=25 m.
?? That would mean the hypotenuse is sqrt(5^2 + 25^2) m.
haruspex
Insights Author
5,445
Perhaps it should have said ?? That would mean the hypotenuse is sqrt(5^2 + 25^2) m.
That would make it far taller and steeper than any I've seen.
More likely the two numbers are swapped over: 5m vertical, 25m hypotenuse.
Related Threads on Sliding on a water slide
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
