How to Calculate the Slope of a Line Through Two Points?
  • MHB
  • Thread starter mathdad
  • Tags
    Line Slope
In summary, the slope of a line is a measure of its steepness or incline, calculated by dividing the change in the y-coordinate by the change in the x-coordinate between two points on the line. A positive slope indicates an increase in the dependent variable as the independent variable increases, while a negative slope indicates a decrease. The slope of a horizontal line can be 0, meaning that the dependent variable remains constant regardless of the change in the independent variable.
mathdad
1,283
Show that the slope of the line passing through the two points (x, x^2) and (x + h, (x + h)^2) = 2x + h.
Must I use m = delta(y)/delta(x)?
Mathematics news on Phys.org
Yup.
-Dan
topsquark said:
Yup.
-Dan
Perfect. I can now proceed.
1. What is the slope of a line?
The slope of a line is a measure of its steepness or incline. It represents the rate of change of the dependent variable with respect to the independent variable.
2. How is the slope of a line calculated?
The slope of a line can be calculated by dividing the change in the y-coordinate (vertical change) by the change in the x-coordinate (horizontal change) between two points on the line. This is represented by the formula: slope = (y2 - y1) / (x2 - x1).
3. What does a positive slope indicate?
A positive slope indicates that the line is increasing from left to right, meaning that the dependent variable is increasing as the independent variable increases.
4. What does a negative slope indicate?
A negative slope indicates that the line is decreasing from left to right, meaning that the dependent variable is decreasing as the independent variable increases.
5. Can the slope of a line be 0?
Yes, the slope of a horizontal line is 0. This means that there is no change in the y-coordinate as the x-coordinate changes, resulting in a flat line. In this case, the dependent variable remains constant regardless of the change in the independent variable.
  • General Math
  • General Math
  • General Math
