Why is the Small LED on my Screwdriver Lighting Up?
  • Thread starter Mephisto
  • Tags
    Led
In summary, some devices, such as the mentioned screwdriver and iPod docking station, have the ability to detect the small electrical signals emitted by the human body. This is due to the presence of circuitry for detecting AC voltage and the fact that the human body emits small electrical signals related to the heartbeat. This phenomenon can also be seen with an oscilloscope probe. The presence of these signals can cause the LED to light up or create a buzzing noise through speakers.
Mephisto
93
I have a small screwdriver which has a small LED in it. When you stick it into something like an outlet, and hold your finger on the other end, the LED lights up. Today though I held both ends of the screwdriver and the LED lighted up. This confuses me tremendously... Doesn't that indicate there is a potential difference between the two fingers? Otherwise what makes electricity flow and light up the LED? Does anyone know these screwdrivers? My best hypothesis is that it must have a battery in it or something, and some type of a small ammeter or something?
It actually does have a battery inside. Lol, you thought you could obtain energy from your fingers? Thats great. Such a device is chiefly called a Voltage Detector or Voltage detection screwdriver.
C.f.: Patent 6100679 - Abstract & Schematics
(google is sortof starting to scare me with its versatility)
no i thought that the LED just requires VERY little voltage to start shining... And it's pretty dim too so i thought it was a possibility that I was charged or something... but not uniformly? sounded weird. Anyway the thing that confused me the most was that the screwdriver is REALLY old, and the battery would have to last a really long time as well.
ok cool good to know... and i was right :p
thanks for the link
there still is the issue however of why it lights up on contact with my skin...
"A tool for indicating the presence of potentially dangerous voltages to the user includes circuitry for detecting the presence of an AC voltage..."
i'm still not exactly sure how it works. it's probably easy to detect high voltages, but the voltage drop between my two fingers should be pretty much 0.
When I hold the tip of an oscilloscope probe between thumb and forefinger, I see a periodic trace on the scope.
Similarly, I have an iPod docking station with speakers. It includes a cable (mini plug to mini plug) for connecting auxiliary devices other than the iPod to its speakers. When I connect myself to it (i.e. I turn on the unit, plug one end of the cable into the mini jack, and hold the contact of other end between thumb and forefinger), I hear a buzzing noise over the speakers.
The human body emits some type of electrical signal. I think it's related to what keeps one's heart beating, but I don't know too much about this topic.
I also am not sure if that is what is lighting your LED.
Can anyone explain the cause of these phenomena in more detail?
The human heart gives off a small electrical field. Thats how most heart rate moniters work, by picking up this field. Also has to do with why they shock you to get your heart started agian.
What is a small LED on a screwdriver?
A small LED on a screwdriver is a tiny light that is attached to the handle of the screwdriver. It is designed to provide additional lighting when using the screwdriver in dark or dimly lit areas.
How does the small LED on a screwdriver work?
The small LED on a screwdriver is powered by a small battery and is usually activated by a switch on the handle. When the switch is turned on, the LED emits light, making it easier to see the area where the screwdriver is being used.
What are the benefits of a small LED on a screwdriver?
The main benefit of having a small LED on a screwdriver is increased visibility. It can help to illuminate dark or hard-to-reach areas, making it easier to complete tasks with greater accuracy and efficiency.
Can the small LED on a screwdriver be replaced?
Yes, in most cases, the small LED on a screwdriver can be replaced if it stops working. However, the process of replacing the LED may vary depending on the make and model of the screwdriver. It is important to refer to the manufacturer's instructions for proper replacement.
Are there any safety concerns with using a small LED on a screwdriver?
No, as long as the screwdriver is used according to the manufacturer's instructions, there should be no safety concerns with using a small LED on a screwdriver. However, it is important to always handle any tools, including screwdrivers, with caution to avoid injury.
  • Electrical Engineering
  • Other Physics Topics
