Small oscillations of a spring-pendulum
  1. Sep 10, 2013 #1
    A spring of rest length L (no tension) is connected to a support at one of the ends and has a mass m attached to the other. Write the Lagrange equations. Discuss the movement for small departures from equilibrium.
    2. Relevant equations
    I did the first part, and I found the equations of motion to be
    \ddot r = r\dot\phi^2 + g \cos\phi - \frac km (r - L)
    \ddot \phi = -\frac gr \sin\phi - \frac 2r \dot r \dot\phi,
    where r measures the distance of the mass from the pendulum pivot and ɸ measures the angle the pendulum makes with the vertical. I am told that these are correct.
    3. The attempt at a solution
    Now I want to think about the case of small oscillations, so I will discard all terms which are second-order or higher in small quantities. Therefore I can lose the ##\dot\phi^2## term, the ##\dot r\dot\phi## term, and all powers of ɸ greater than 1 in the expansion of sin ɸ and cos ɸ.
    This gives me the right answer...but I don't actually understand what I just said. How do I prove that ##\dot r## and ##\dot\phi## are, in fact, small quantities?
Draft saved Draft deleted
