Homework Help: Small proof
  1. Jun 17, 2009 #1
    Show that A and AT share the same eigenvalue.
    2. Relevant equations
    3. The attempt at a solution
    let v be the eigenvector
    Av=Icv
    since ATv=ITcv
    and IT=I,
    ATv=Icv
    so ATv=Icv=Av
    so A and AT must have the same eigenvalue.
  3. Jun 17, 2009 #2
    Cyosis
    How did you go from the first to the second step?
  4. Jun 17, 2009 #3
    If Av=Icv, then the transpose of Icv is Icv since the transpose of I is I.
    Now (Icv)T=(Acv)T since Icv=Av
    since neither c nor v are matrices, they get pushed aside to
    get ITcv=ATv
  5. Jun 17, 2009 #4
    Cyosis
    Yes, but a column vector is an mx1-matrix. When you transpose an mx1 matrix you get a 1xm matrix, called a row vector. My point is v and v transposed aren't exactly the same.
  6. Jun 17, 2009 #5
    Oh okay. So (Av)T= (Ivc)T=(Ic)T(v)T=c(I)T(v)T=cI(v)T which has the same eigenvalue
    as A, so AT and A both have the same eigenvalue.
  7. Jun 17, 2009 #6
    Cyosis
    I don't quite see how you drew your conclusion. [itex](Av)^T=v^T A^T[/itex]. Just try to compute [itex]I v^T[/itex] with a small vector, you will notice they are incompatible.
  8. Jun 17, 2009 #7
    ok how about this: don't factor out vT keep it this way:
    since Av=cIv, (Av)T=(cIv)T and
    factor out c to get c(Iv)T which can be transposed.
    wait, never mind....I'm fixing this.
  9. Jun 17, 2009 #8
    Cyosis
    Sure, but how do you conclude from that, that A^T has eigenvalue c?
  10. Jun 17, 2009 #9
    Oh that's right. Let me reprove this. Let c be at position j,j on A. Transposing
    the matrix lets c remain on j,j. So multiplying this by
    the eigenvector v gives the column matrix Icv. This gives
    the same result as not transposing A in the first place, since c will
    still remain on j,j no matter what, and as a result, it would wind up at position 1,j on the
    column matrix. Now, since Av=ATv,
    c must be in both matrices A and AT.
    Take note that we know that eigenvalues are found on the diagonals of
    invertible matrices, which is why j,j was chosen.
  11. Jun 17, 2009 #10
    Cyosis
    The matrix
    [tex]
    \left( \begin{matrix} 1&1 \\ 1&1 \end{matrix} \right)
    [/tex]
    Has eigenvalues 2 and 0, neither of them are shown on the diagonal.
    I would personally use the inner product to prove this.
  12. Jun 17, 2009 #11
    Dick
    You could also think about using det(A)=det(A^T).
  13. Jun 17, 2009 #12
    Oh, one thing: I am using the Axler book as a main book, and he covers eigenvectors
    before inner products, and everything before determinants, so I can't apply those,
    but I do appreciate your suggestions. But given cyosis's matrix, it makes sense that
    all matrices with entries that equal each other also have eigenvalues besides 0, I messed
    up there because I didn't consider that.
    So I'll split my proof into 3 cases. Case 1: A is an invertible matrix. Case 2: A is a matrix
    where all entries are the same, Case 3: A is noninvertible and not all of its entries are the
    same. Is this a good idea? I would use determinants or inner products if I knew what they were. If there is no other way, I won't do this proof until
    later on when I know more about them. But thank you for the suggestions.
    Take note that when I feel I need to practice a bit more I use other sources, but they vary in topic sequence.
  14. Jun 17, 2009 #13
    Cyosis
    I find it hard to believe you are studying eigenvectors/eigenvalues yet have not been exposed to determinants. This would mean you are not capable of calculating eigenvalues of matrices yet, but your posts suggest otherwise. Could you show me perhaps how to calculate the eigenvalues of the matrix I posted earlier?
  15. Jun 17, 2009 #14
    Dick
    You could also work around not having determinants yet. If c is an eigenvalue, then X=A-c*I is a singular matrix. Can you prove X is singular iff X^(T) is singular? How would that prove what you want to prove?
  16. Jun 17, 2009 #15
    I can see three justifications for X to be singular. First, if A=cI, then X is a zero
    matrix, and 0 is an eigenvalue for every vector, and X is singular for being
    a zero matrix.
    Second, if A-cI is nonzero but singular, then as long as the number of rows
    the column matrix (representing a vector) equals the number of columns
    in A and cI, Av would equal cIv so Av-cIv=0
    Now, if A-cI were to be nonsingular, then (A-cI)v would not be zero,
    so we would have Av=/=cIv so in this case v is not an eigenvector of A.
    I know this isn't the actual proof, just want to see if I understand the
    significance of X being singular.
  17. Jun 17, 2009 #16
    Dick
    Singular doesn't mean A-cI equals 0. It means there is a nonzero vector v such that (A-cI)v=0. Which is what your second and third argument correctly say. You are overcomplicating this already. The question you should be thinking about, instead of trying to find multiple ways to prove the obvious, is why if X=A-cI is singular is X^T also singular?
  18. Jun 17, 2009 #17
    X=A-cI a jxn matrix with j=/=n.
    Consider the column with elements aj,1 to aj,n.
    If j>n then (at least) this column (lets call it column A) becomes a zero column after row reducing
    which results in a matrix with less columns than X so X is singular.
    Now transposing causes column A to become a row,
    with column A being the one at the bottom. Row reducing X^T
    gives a matrix with at least one less row (column A becomes a 0 row) than X^T since t so X^T is singular.
    This is a result of A being one of (or the only) the extra columns, so it becomes one of (or the only)
    extra rows that get "eliminated" after row reducing.
  19. Jun 17, 2009 #18
    Dick
    You are thinking in the right direction. You proved row rank=column rank, right? So in the nxn case if rank is <n then both matrices are singular. You really don't have to think about any other case. If the matrix isn't square then the concept of an 'eigenvector' doesn't exist. Why not?
  20. Jun 17, 2009 #19
    because I doesn't exist.
  21. Jun 17, 2009 #20
    :biggrin: I be thanks you
  22. Jun 17, 2009 #21
    Dick
    Your attempt at levity is highly appreciated. Ha. Ha. But it's actually pretty good. As "I doesn't exist" is not grammatical as the idea that two vectors with different dimensions could be equal is also not grammatical.
  23. Jun 17, 2009 #22
    Dick
    Too fast. You leapfrogged me before I realized I should quote you.
  24. Jun 17, 2009 #23
    What? How did the posts switch??:eek:
  25. Jun 17, 2009 #24
    Dick
    I didn't quote you in the previous post. Realized it was important, deleted the post. Went back quoted you in a new post. By that time you had already quoted my post. Oh, you know how these time travel things go.
  26. Jun 17, 2009 #25
    You should post a thread in this forum explaining your time machine.
