Small understanding
  • Thread starter Sumanta
Sumanta
Hi,
This is not a homework question since I am out of college for a long time.
I was trying to understand the following that [0,1] /\ Q is not closed in R.
My understanding is that u must take a sequence (since this is a metric space) of the form m/n s.t m < n and create a sequence.
So I was trying to construct sequences like 1/2, 2/3, 3/4 but they seemed to be all ending within [0,1] /\ Q. I am not sure but do I have to take a sum or sth but I am not sure how to prove it.
Answers and Replies
mathman
539
(I am assuming that Q means rational nos. and R means real nos.). Take any irrational number between 0 and 1 and let the rational number sequence be the the sequence where the nth term is the truncation of the decimal expansion of the irrational after n decimal places.
HallsofIvy
41,847
969
Just giving an example of what mathman said: [itex]\sqrt{2}{2}[/itex] is irrational and is 0.70710678118654752440084436210485...
Each number in the sequence 0.7, 0.70, 0.707, 0.7071, 0.70710, 0.707106,... is a rational number because it is a terminating decimal; but the sequence as a whole converges to the irrational number [itex]\frac{\sqrt{2}}{{2}}[/itex]
Hurkyl
Staff Emeritus
You're working from the wrong direction. Rather than trying to come up with a sequence of rationals and hope that its limit is irrational... you should pick the irrational, and then try and find a sequence of rationals that converges to it.
Sumanta
Thanks a lot for clearing the lacunae in my understanding. I think the basic idea is that u need to show that if u wiggle the rational number a bit u will fall into the set of irrational numbers, which is clearly proved by the sqrt(22) example.
Thank u a lot for the same.
Eighty
53
Actually that was sqrt(2)/2 (how could the square root of 22 be less than 1?). You should read what Hurkyl said. The simplest irrational you can think of in the interval is sqrt(2)/2, and constructing a sequence that converges to it is easy, as shown by HallsofIvy.
HallsofIvy
41,847
969
'Cause I'm nothing if not simple!
ZioX
370
Do you understand why this argument suffices?
Suggested for: Small understanding
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
