Smooth elevator ride
  • Thread starter PFuser1232
For a smooth (“low jerk”) ride, an elevator is programmed to start from rest and accelerate according to
$$a(t) = \frac{a_m}{2}[1 − \cos{\frac{2\pi t}{T}}] \:\:\:\:0 ≤ t ≤ T$$
$$a(t) = -\frac{a_m}{2}[1 − \cos{\frac{2\pi t}{T}}] \:\:\:\:T ≤ t ≤ 2T$$
Where ##a_m## is the maximum acceleration and ##2T## is the total time for the trip.
(a) Draw sketches of ##a(t)## and the jerk as functions of time.
(b) What is the elevator’s maximum speed?
(c) Find an approximate expression for the speed at short times near the start of the ride, ##t ≪ T##.
2. Homework Equations
##j = \dot{a} = \ddot{v}##
[/B]
The sketch required for part (a) is trivial, so I won't go over the details of the two sketches.
Now, for part (b), I found the value of ##t## for which the acceleration is zero, and used integration to find the velocity (or rather, maximum velocity) at that value of ##t##. The problem is, there's more than one value of ##t## for which the acceleration of the elevator is zero. In fact, the acceleration is zero at ##t = 0## inspite of the fact that ##v(0) = 0##. I feel like I have made some kind of error somewhere.
Answers and Replies
DEvens
Education Advisor
457
Maybe if you plot the speed as a function of time? That might help with your intuition and your confusion about maximums and so on.
Remember that a full plot of a function includes things like maximums, minimums, zeroes, and inflection points.
##a(t) = 0## implies maximum speed (maximum/minimum velocity), right? Why am I getting a contradiction for ##t = 0##?
gneill
Mentor
20,925
2,866
At time t=0 the elevator starts from rest. You don't expect it to suddenly jump to maximum speed instantaneously, right?
Did you sketch the acceleration profile (say for the first acceleration formula)? Does the acceleration ever change sign through the acceleration phase?
Do you expect the elevator to attain maximum speed before or after all the acceleration has taken place?
I did plot acceleration as a function of time, it didn't change signs through the first phase. I guess my question is more of a calculus question; doesn't ##f'(a) = 0## imply that ##f## has a maximum/minimum value when evaluated at ##a##?
gneill
Mentor
20,925
2,866
That's the case unless it's a saddle point. Use the second derivative test to confirm max or min. Here it should be clear from the physical scenario whether you have max or min when t = 0 or t = T.
What about ##t = 2T##?
gneill
Mentor
20,925
2,866
T = 2T corresponds to the time when the elevator has been brought to rest.
Your first a(t) expression describes taking the elevator from rest to its "cruising" speed, while the second a(t) expression describes slowing the elevator from cruising speed back to rest. That's why the second expression is negative: it's a deceleration.
So I should find the velocity at time ##T## by integration as follows:
$$v(T) = v(0) + \int_0^T a(t) dt = \int_0^T a(t) dt$$
For part (c), I could use integration again to find velocity as a function of time, which would yield the sum of a linear term and a sinusoidal term. Would the small angle approximation be appropriate in that case?
haruspex
Insights Author
2020 Award
36,212
6,827
Since they indicate the conditions for that would be met, I would say so.
$$v(t) = \int_0^t a(t') dt' = \int_0^t [\frac{a_m}{2} - \frac{a_m}{2}\cos{\frac{2\pi t'}{T}}] dt' = \frac{a_m}{2} t - \frac{a_m}{2} \frac{T}{2\pi} \sin{\frac{2\pi t}{T}} = \frac{a_m}{2} t - \frac{a_m T}{4\pi} \sin{\frac{2\pi t}{T}}$$
For very small ##t##, the second term becomes approximately equal to the first term (by the small angle approximation), so ##v(t) ≈ 0##
Is there another way to find an approximation to ##v(t)## for very small ##t##?
haruspex
Insights Author
2020 Award
36,212
6,827
So include the next term in the expansion of sin().
How do we write the most general expression for ##v(t)##? I'm confused because acceleration is piecewise defined. Should we integrate the first part of the acceleration function from ##0## to ##T## (giving us ##v_{max}##), then add the integral of the second part of the acceleration function from ##T## to ##t## where ##t## lies in the interval ##[0,2T]##?
haruspex
Insights Author
2020 Award
36,212
6,827
Yes. The full description of v(t) is likely to involve separation into the two time ranges, just as it did for the acceleration.
So to find the distance ##D## traveled by the elevator in time ##2T## I would have to integrate the velocity function (which itself is split into two integrals; one from ##0## to ##T## and the other from ##T## to ##t##) from ##0## to ##2T##.
haruspex
Insights Author
2020 Award
36,212
6,827
Yes.
Related Threads on Smooth elevator ride
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
10K
  • Last Post
15K
  • Last Post
