Which would be the stronger nucleophile in a polar aprotic solvent?
HCl or HIIn summary, the stronger nucleophile in a polar aprotic solvent would be H2S for a) and (CH3)3P for b). This is because in protic solvents, larger atoms tend to be stronger nucleophiles, while in aprotic solvents, smaller atoms are more nucleophilic. The given concept in the book is incorrect, as in protic solvents, bonds between similar sized atoms are stronger, making smaller atoms more nucleophilic.
lha08
164
a) H2O or H2S
b) (CH3)3P or (CH3)3N
I'm really confused because in my book, it says that in protic solvents, the larger atoms (I-) are stronger nucleophiles than smaller ones (F-). Then it says that it is opposite for when it is an aprotic solvent (e.g. F- is more nucleophilic than I-)
In this case, the answer to b) is H2S and c) is (CH3)3P, but shouldn't it be the opposite??
The answers given for the question is correct and the concept given is wrong.consider protic solvent it consists of H+ ions since bonds between similar sized atoms is strong,the bond between smaller atoms will be stronger if F- is in polar protic solvent,it forms HF molecule which will be more stable than other halogen hydrides
In a polar aprotic solvent, the stronger nucleophile would be the one that is more polarizable. This means that it has a larger electron cloud that is easily distorted, allowing it to attack electrophiles more easily. In this case, the answer to a) would be H2S and the answer to b) would be (CH3)3N.
In general, larger atoms or molecules are more polarizable than smaller ones. However, in the case of aprotic solvents, the smaller atoms or molecules can still be more polarizable due to their electron configuration. For example, (CH3)3N has a larger electron cloud than (CH3)3P, making it more polarizable and thus a stronger nucleophile in a polar aprotic solvent. Similarly, H2S has a larger electron cloud than H2O, making it a stronger nucleophile in this case.
It is important to note that nucleophilicity can also be affected by other factors such as steric hindrance and solvent effects. So, while larger atoms or molecules may generally be more nucleophilic in protic solvents, this may not always be the case in polar aprotic solvents due to other factors at play.
1. What exactly is a polar aprotic solvent?
A polar aprotic solvent is a solvent that has a polar covalent bond, but does not have a hydrogen atom bonded to an electronegative atom such as oxygen or nitrogen. Examples include acetone, DMF, and DMSO.
2. How does a polar aprotic solvent affect nucleophilicity?
A polar aprotic solvent can increase the nucleophilicity of a molecule by stabilizing the negative charge on the nucleophile, making it more available to attack electrophilic species. This is due to the ability of the solvent to solvate cations, reducing their ability to stabilize the nucleophile.
3. What makes a nucleophile stronger in a polar aprotic solvent?
A nucleophile is considered stronger in a polar aprotic solvent when it is able to retain its negative charge and attack electrophilic species more readily. This is typically seen in nucleophiles that are larger, less electronegative, and less sterically hindered.
4. Can you give examples of strong nucleophiles in polar aprotic solvents?
Some common examples of strong nucleophiles in polar aprotic solvents include iodide ions, thiolates, and cyanide ions. These nucleophiles are able to retain their negative charge and attack electrophiles with high reactivity and selectivity.
5. Are there any exceptions to the trend of stronger nucleophiles in polar aprotic solvents?
Yes, there are some exceptions to this trend. For example, some smaller, more electronegative nucleophiles such as fluoride ions can also exhibit strong nucleophilic behavior in polar aprotic solvents due to their ability to form strong hydrogen bonds with the solvent molecules.
