Snells law - help please
  • Thread starter Sprattboy
Snells law -- help please
A light ray approaches a glass block at 30° to the normal. The refractive
indices of air and water are 1 and 1.5 respectively At what angle will the light
be refracted?
This uses Snells law
I did Sin 30 / Sin r = 1 / 1.5
I then multiplied both sides in order to get rid of sin 30.
After that, I got Sin r = 1/1.5(xSin30)
This gave me an answer of -1.48
When I do inverse sine it gives me an error
What did I do wrong???
Answers and Replies
SammyS
Staff Emeritus
1,035
indices of air and [STRIKE]water[/STRIKE] glass (?) are 1 and 1.5 respectively At what angle will the light
be refracted?
Check your algebra !
I have
Check it again and again, just to be sure, a minus answer should be rather unlikely in elementary examples.
You did your fractions wrongly.
You should have got this:
[itex]\frac{1}{sin(r)}=\frac{1}{1.5(sin(30))}[/itex]
201
Make sure your calculator is set for degrees instead of radians. You're getting a negative sign because you're using radians. That's what happens when you blindly follow the calculator without a clue of what to expect. You end up eating calculator garbage.
adjacent
63
What dauto said. and:
Since you have done that,(Did it using radians), be sure to reset your calculator especially before exams.
Related Threads on Snells law - help please
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
