So simple yet so problematic
  • Thread starter Athe
In summary: If the system is in a state of superposition of multiple reference frames, which one should be used for a measurement?. A particle is said to be "in a state of superposition" of two frames if it exists simultaneously in two different frames. When a particle is measured, which of the frames it is measured in is determinate?.
Athe
If we consider a system (say an electron) with respect his own reference frame, we find that it is placed in an exact position (let's say the origin) and it has an exact momentum (it is at rest with respect to his own reference frame); due the very definition of such reference frame.
HEISENBERG O_O
Quantum mechanics excludes the existence of proper reference frames?. If so, what happens with proper time?. Can we talk about simultaneity when dealing with quantum mechanics? Do 'simultaneous measurements' (of non-cunmuting observables or whatever) have sense?
HEISENBERG O_O
The problem here is that you made an explicit assumption that is your starting point which is not substantiated by evidence. You have made an explicit assumption that an "electron" is a point object like a tennis ball that can be defined clearly as to where it is in such a way that you can transform to its reference frame. How are you sure this is valid when there's plenty of indication that a "smearing" of position simultaneously can also be interpreted for the electron? Look at H2 bonding or even atomic orbitals for examples.
When you start off with the wrong premise, then any kinds of nonsensical conclusion can be possible. We don't have such luxury in physics. The parameters and scenario that we can use must be based on some ground of something realistic. Unrealistic assumption will result in unrealistic results.
Zz.
QUOTE]
I don't want to complain, I just want answers. I want to study a quantum system of two particles in a minkowskian space-time, and I have just realized I have no clue of how to draw their universe lines. I want to perform a simultaneous measurement in each of them, first simultaneous with respect the laboratory frame and then with respect an inertial frame moving with velocity v respect to the former.'Classically', the particles are at rest respect to the lab frame, separated by a space-like interval. But with Heisenberg operating...
How do quantum mechanics define the proper reference frame of a system?
What does "so simple yet so problematic" mean?
"So simple yet so problematic" refers to a situation or concept that appears easy to understand or solve, but in reality, it presents many difficulties or challenges. It can also describe something that seems straightforward but has unexpected consequences or complications.
Why is something considered "so simple yet so problematic"?
There are many reasons why something may be labeled as "so simple yet so problematic." It could be due to a lack of understanding of the underlying complexities, unforeseen obstacles, conflicting factors, or the dynamic nature of the issue.
Can something be both simple and problematic at the same time?
Yes, something can be simple and problematic simultaneously. Its simplicity may be apparent, but the problems or challenges it presents are not immediately obvious or straightforward to address.
How do scientists deal with "so simple yet so problematic" situations?
Scientists approach "so simple yet so problematic" situations by breaking down the problem into smaller components, analyzing and testing each aspect, and collaborating with other scientists to find potential solutions. They also use critical thinking and creativity to navigate the complexities and challenges.
What are some examples of "so simple yet so problematic" in science?
Some examples of "so simple yet so problematic" in science include the placebo effect, climate change, the concept of time, and the human brain. These are all seemingly simple concepts but present challenges and complexities that are still being studied and understood by scientists.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
