Homework Help: So, we're playing snooker
  1. Feb 7, 2010 #1
    So, we're playing snooker....
    A (uniform) snooker ball of radius r, at rest on a table, is struck by a cue at a point a distance h above the table. Assume the cue tip is travelling horizontally, in a plane through the centre of the ball. As a result, the ball begins to move with an initial linear speed V0 and angular speed w0.
    Consider the cue as acting with a large force F for a short time. Ignoring the effects of friction between the ball and the table for this time, find an expression for the ratio V0/w0 in terms of h.
    2. Relevant equations
    Once I've sussed the question, I can identify which.
    3. The attempt at a solution
    Well, I'm confused due to the sentence; "Assume the cue tip is travelling horizontally, in a plane through the centre of the ball". This to me means, that h = r? Therefore, if friction is to be ignored this time, the ball will not (initially) rotate?
    If someone could clear this up, I'm sure I can crack on with the next few parts of the question.
  3. Feb 7, 2010 #2
    Doc Al
    Staff: Mentor
    Re: So, we're playing snooker....
    I suspect that it's just a sloppily worded problem, and that the 'in a plane through the center of the ball' should be ignored. (Otherwise your interpretation is correct, but then the problem makes little sense.)
    (This isn't from some textbook, I hope. If it is, give a reference.)
  4. Feb 7, 2010 #3
    I would assume it means in a vertical plane through the centre of the ball. In other words, you are not putting any side spin on it.
  5. Feb 7, 2010 #4
    Doc Al
    Staff: Mentor
    Excellent. That's it.
  6. Feb 7, 2010 #5
    Probably, my Mechanics Lecturer isn't the greatest at writing them.
    Awesome, I'll try it like that. Thanks!
