Solar Energy in Space: Locomotion & Approaching Sun
In summary: They use a nuclear powered ion thruster to do it, but it's less efficient than a Solar thermal engine.
geordief
214
48
Is it possible to use solar energy to provide locomotion in Space?
I appreciate that Solar sails have been mooted but is there any way that the energy from the sun can be used in such a way as to approach the source of the light?
If you can eject some mass (using solar energy, if you like), it is possible.
If you can find some way to catch and accelerate solar wind, it might be possible, but the density is very low.
A solar sail can bring you anywhere more or less. This results from space mechanics, where you go farther from the Sun (or the attracting body) by accelerating on the orbit, and nearer by braking along the orbit.
So in the typical use, a solar sail "tows" and is inclined 45° to the orbital speed and to the Sun's direction, in order to brake or accelerate. Much more efficient, even to go away from the Sun, because paths in a gravity field are very much a matter of kinetic and gravitation energy, but the means used give a speed, so this speed acts far better if it combines parallel with the existing big speed (30km/s for Earth on its orbit!) to produce the V2 effect.
Because Sunlight is stronger nearer to the Sun, a Solar sail is in fact better to reach the inner planets or orbits. One Japanese craft presently uses it that way. I also computed that a Solar sail spacecraft , with very reasonable assumptions, would have reached a Solar polar orbit within two years and have stayed there indefinitely: compare it with Ulysses
http://en.wikipedia.org/wiki/Ulysses_( spacecraft )
which took years to fly by Jupiter because our rockets can't provide 40km/s for a polar Solar orbit. And then, Ulysses flew once over each pole in many years, then all was over. A sail goes there in two years, stays there, changes the distance and inclination at will... Checkmate!
I had some thoughts at Solar sail technology there
http://saposjoint.net/Forum/viewtopic.php?f=66&t=2102
I'm not pleased with the beams I imagined, but other ideas are good to my eyes:
how to thin the polymer film, how to test the unfurling...
To go far and fast away from the Sun, say to the heliopause in few years, a sail would first brake to go near, and from that better position, accelerate and escape our Solar system easily.
There are "amateur" websites especially for that topic, very interesting, with advanced thoughts.
What a sail can't do well is brake when it arrives at an outer planet like Uranus or Neptune. But well, maybe we could have rockets for that purpose, combined with Oberth effect and capture using massive moons.
I consider every space agency should have very active and concrete projects on this topic. This technology IS feasible and brings a lot.
The Solar wind is extremely weak, much more so than Sunlight pressure. It diminishes less than Sunlight with distance but should remain fainter. It has been proposed only because, as being composed of charged particles, it could be deflected by a huge (really) loop of current whose immaterial area weighs nothing. A wire was considered, an electron beam as well, curved by the Sun's induction.
To get more thrust, Sunlight can heat an ejected working fluid, in a "Solar thermal rocket". This is technology at grasp. ESA has a reasearch project for a craft from from Low-Earth-Orbit to geostationary, towing a satellite that has brought the necessary hydrogen, and back to LEO for the next customer, within a few weeks.
Perfectly feasible and very useful. I have thrown a few thoughts at it there
http://saposjoint.net/Forum/viewtopic.php?f=66&t=2164
including a very low-pressure chamber and a windowless hole in the chamber to let the concentrated light in.
I will throw more thoughts at it. Some day.
I consider this is the proper way to transport people to Mars and back. Chemical rockets and hardware preset in Martian orbit would permit a shorter trip to Mars or a short stay on Mars; Solar thermal rockets enable both at the same time.
http://saposjoint.net/Forum/viewtopic.php?f=21&t=1954
Other combinations are possible, like Solar electricity that powers an ion thruster and its variants, but they need much more light collecting area than the Solar thermal engine without saving global mass on a big mission like manned Mars.
On a smaller mission, for instance hopping from one asteroid vicinity to an other, this has been done by JPL with huge success.
1. What is solar energy in space?
Solar energy in space refers to the use of energy from the sun to power spacecraft and satellites. This energy is collected by solar panels, which convert sunlight into electricity that can be used to power the various systems and instruments on board.
2. How does locomotion work in space using solar energy?
Locomotion in space using solar energy involves using solar sails or solar electric propulsion systems. Solar sails use the pressure of sunlight to propel a spacecraft forward, while solar electric propulsion systems use electricity generated from solar panels to power thrusters and move the spacecraft.
3. What are the advantages of using solar energy for space travel?
There are several advantages to using solar energy for space travel. First, it is a renewable and virtually unlimited source of energy. It also does not produce any emissions or waste, making it a clean and sustainable option. Additionally, solar energy is lightweight and can be easily used in space without the need for heavy and expensive fuel sources.
4. How close can a spacecraft approach the sun using solar energy?
The closest a spacecraft has been to the sun using solar energy is the Parker Solar Probe, which became the first spacecraft to "touch" the sun's atmosphere in 2018. It was able to safely approach within 15 million miles of the sun's surface.
5. What are the potential future developments for using solar energy in space?
Scientists and engineers are constantly working on improving and advancing the use of solar energy in space. Some potential future developments include more efficient solar panels, new methods of storing and using solar energy, and advancements in solar sail and solar electric propulsion technology. There is also ongoing research into the use of solar energy for long-distance space travel, such as to other planets or even beyond our solar system.
  • Aerospace Engineering
  • Electrical Engineering
  • Materials and Chemical Engineering
  • Astronomy and Astrophysics
