• Support PF! Buy your school textbooks, materials and every day products Here!
Solid State II
  • Thread starter Nusc
1. Homework Statement
Given some dispersion relation for the tight binding approximation in 2D:
e(k_x,k_y) = -2t_1[cos(k_x*a)+cos(k_y*a)]-4t_2[cos(k_x*a)cos(k_y*a)]
Show that the density of states has a logarithmic singularity for some choice of parameters t_i.
2. Homework Equations
g(e)de=g integral dS/(2*pi)^3 *1/|grad e(K)|
3. The Attempt at a Solution
When it says logaritmic singularity is it referring to von hove singularity?
First I expanded the cosines.
-2t_1[2-k_x^2*a^2/2 -k_y^2*a^2/2] -4t_2[1+k_x^2*a^2 k_y^2*a^2
Then what do I do?
Answers and Replies
979
I don't think the expression you've got there for the density of states in the one you want --- it's for 3D, where as you want the 2D case. Also, are you sure that you actually have to show there is a *logarithmic* singularity? Because I think the proof for that is *really* quite long. Otherwise, just show that the gradient of e(k) has a zero on contour lines with finite extent --- it will have zeros at the maxima and minima, but the contour lines there have zero length.
754
What formula do I need for the 2D case?
There is another one in ashcroft
g_n(e) = g integral (d^3k/(2*pi)^3 delta (e - e_n(k))
Is that the one I want?
979
All of those assume a 3D situation. You want:
[tex]g_n(E) = \int \frac{d\mathbf{k}}{(2\pi)^d} \delta\left(E - E_n(\mathbf{k})\right)[/tex]
where we've used the fact that for most of the things we care about, k-space is discrete with a volume per k-state of [tex]1/(2\pi a)^d[/tex] (a is the crystal size, d is the dimension of the space). The factor of [tex]a^d[/tex] is cancelled by dividing by the volume of the entire crystal.
754
"Otherwise, just show that the gradient of e(k) has a zero on contour lines with finite extent --- it will have zeros at the maxima and minima, but the contour lines there have zero length."
SO given
[tex]
e(k_x,k_y) = -2t_1[\cos(k_x*a)+\cos(k_y*a)]-4t_2[\cos(k_x*a)\cos(k_y*a)]
[/tex]
Should I expand?
Do I take the gradient with respect to k or (k_x and k_y)
If I recall correctly, you want to consider the gradient of E in the direction *perpendicular* to the iso-energy contour, since that is what appears in the denominator (once you expand out the delta function). But, since the gradient along the contour is going to be zero, you can just look for critical points of E --- i.e. [tex]dE/dk_x = dE/dk_y = 0[/tex]. After finding these, identify the fact that some of them are neither minima or maxima --- i.e. saddle-points. These should then lie on contour lines of finite extent.
However, to show that the divergence is logarithmic, rather than say, 1/x, would involve rather a lot more work. If this is for an undergraduate course (well, it would be undergrad in the UK, I don't know about elsewhere), then it's unlikely that the question wants you to actually show the nature of the divergence.
754
After Taylor expanding E(k) I get:
[tex]
e(k_x,k_y) = a^2(-t_1+4t_2)(k_{x}^2 +k_{y}^2) +4(t_1+t_2)
[/tex]
then
[tex]
\frac{dE}{dk_x}=0 \rightarrow 4t_2=t_1
\frac{dE}{dk_y}=0 \rightarrow 4t_2=t_1
[/tex]
Does that suffice to show the log sing for a choice of parameters t_i?
Now if I want to obtain the density of states how do I do that?
979
Wait, why did you Taylor expand? There shouldn't be a need to...
And I would personally think that is sufficient, though of course you should ask your course supervisor or TA or whatever you have at hand.
The density of states is going to be infinite at a divergence...?
754
so if
[tex]
\sin(k_x a)(2t_1 a+ 4t_22 a \cos(k_y a)) =0
[/tex]
[tex]
\sin(k_y a)(2t_1 a+ 4t_22 a \cos(k_x a)) =0
[/tex]
Also given t_1 > 0
When are these neither min and max? I can't remember anything about multivariable calculus.
a is non-zero value
If t2 is zero then that reduces to the tight binding approx.
is sin(kxa) zero or non zero?
If kx zero it reduces to t1=-2cos(kya)
if ky zero then t1 =-2cos(kxa)
The equations are simultaneous equations, so just solve them with the usual methods. Given that you've already got them in factors, you should be able to read off the 4 possibilities. To tell whether they are maxima or minima, you can go via looking at the 2nd derivatives: http://en.wikipedia.org/wiki/Hessian_matrix#Second_derivative_test
754
Okay done. Now I have to evaluate this numerically:
[tex]
[/tex]
Both ti's that I obtained were maximum. Which t's should I use in my dispersion relation?
754
What are my limits of integration?
Related Threads for: Solid State II
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
