Difference between Intrinsic & Extrinsic Behaviour of a Semiconductor
In summary: There is no direct equation for this, but approximate expressions for the chemical potential can be used to find the temperature at which both intrinsic and extrinsic behaviour are valid. However, without knowing how the intrinsic carrier concentration varies with temperature, it is difficult to accurately determine this temperature. In summary, the difference between extrinsic and intrinsic behaviour in a semiconductor is the presence or absence of impurities. The temperature at which a semiconductor reverts to intrinsic behaviour can be determined by calculating the Fermi Level at different temperatures and finding the temperature at which it is midway between the conduction and valence band. Without knowing how the intrinsic carrier concentration varies with temperature, it is difficult to accurately determine this temperature.
Claude Bile
1. What is the difference between extrinsic and intrinsic behaviour in a semiconductor? How can you determine what temperature a semiconductor material such as Silicon will revert to intrinsic behaviour, given the donor, intrinsic carrier concentration and the energy gap?
- I am thinking that intrinsic/extrinsic behaviour is related to the Fermi level and the donor and acceptor concentrations at a temperature, T. Intrinsic behaviour has the Fermi level close to midway between the valence and conduction bands, with nearly equal concentrations of donor and acceptor ions. Extrinsic behaviour has the Fermi level close to the conduction band (or valence band). I am looking for confirmation as to whether this is correct, and if not, where I am going wrong.
- I do not have an equation that gives a direct answer to this question. The best I have managed is gaining approximate expressions for the chemical potential for both intrinsic and extrinsic behaviour and showing at which temperature they are both valid. My main difficulty is that we are only given the intrinsic carrier concentration at room temperature and are not told how it varies with temperature. Is there an equation that gives this also, with only the information given above as stated in the 1st paragraph?
The difference between extrinsic and intrinsic behaviour in a semiconductor is that extrinsic behaviour occurs when donor or acceptor impurities are added to the semiconductor, while intrinsic behaviour occurs without any impurities. The temperature at which a semiconductor material such as Silicon reverts to intrinsic behaviour can be determined by calculating the Fermi Level of the material at different temperatures using the donor, intrinsic carrier concentration and the energy gap. By plotting the Fermi Level against temperature, the temperature at which the Fermi Level is midway between the conduction and valence band can be determined, which is the temperature at which the semiconductor reverts to intrinsic behaviour.
1. What is the definition of intrinsic behavior in a semiconductor?
Intrinsic behavior in a semiconductor refers to the natural or inherent properties and characteristics of the material itself. These properties are not influenced by external factors such as impurities or external electric fields.
2. How does intrinsic behavior differ from extrinsic behavior in a semiconductor?
Extrinsic behavior in a semiconductor refers to the properties and characteristics that are affected by the presence of impurities or external electric fields. These properties are not inherent to the material and can be manipulated or controlled.
3. What are some examples of intrinsic behavior in a semiconductor?
Examples of intrinsic behavior in a semiconductor include the band gap, carrier mobility, and doping concentration. These properties are determined by the material's composition and structure.
4. How does extrinsic behavior impact the performance of a semiconductor device?
Extrinsic behavior can greatly impact the performance of a semiconductor device. For example, impurities can change the electrical conductivity and carrier concentration, while external electric fields can affect the device's speed and efficiency.
5. Can the intrinsic and extrinsic behavior of a semiconductor be controlled?
Yes, the intrinsic and extrinsic behavior of a semiconductor can be controlled through various methods such as doping, applying external electric fields, and manipulating the material's composition. This allows for the customization of semiconductor devices for specific applications.
  • Atomic and Condensed Matter
  • Electrical Engineering
