Solid-Vapour Coexistence
  1. Jun 15, 2011 #1
    Hi
    I was wondering if, for water, is it possible for ice and water vapour to co-exist at some temperature and pressure due to the presence of air (not phase equilibrium among itself) like we see for liquid water and water vapour in psychrometrics, why or why not?
    Thanks.
  3. Jun 16, 2011 #2
    Mapes
    Any solid coexists with a gas phase, because all materials have some non-zero vapor pressure. What do you mean by "due to the presence of air"?
  4. Jun 18, 2011 #3
    Hi
    Sorry for not being clear, my question is kind of confusing. For water, liquid and vapour can coexist (at say 1 atm and 25 degrees celcius) when exposed to air which explains how a cup of water becomes empty over time at conditions below its phase change on the phase diagram. I was wondering if such phenomenon is also possible if we have ice instead of liquid water (is there a condition where if I put a piece of ice in a glass exposed to air it would turn into vapour directly without melting). I hope this is less confusing.
    Thanks
  5. Jun 19, 2011 #4
    Mapes
    It is possible and it is called http://en.wikipedia.org/wiki/Sublimation_%28phase_transition%29" [Broken].
  6. Jun 20, 2011 #5
    Hi
    Thanks for the response. Sublimation still occurs when the system contains a pure substance (e.g. water) and is based on the phase diagram. For a cup of liquid water that is left at room temperature and pressure, it becomes vapour because of the presence of air and the psychrometric chart is used to determine humidity/how much vapour etc. as the phase diagram is only valid for a closed system with pure substance. I was wondering if such chart/phenomenon exists if the water was ice to begin with and whether ice can directly vaporize if the system contains air and the ice not just H2O alone.
  7. Jun 20, 2011 #6
    Mapes
    No; sublimation is a phase change from the solid to the gas state. Evaporation is a phase change from the liquid state (e.g., water) to the gas state.
    Yes, ice still sublimates even if it is surrounded by air. Some of the H2O molecules bounce off air molecules and condense back on the ice, but the net reaction is from ice to gas. Try leaving an ice tray in your freezer for a few months; the ice cubes will gradually disappear. (Even if the ice is mixed with another substance such as salt. Note that the salt's vapor pressure is far too low for it to evaporate noticeably within a time span of years. The salt would be left behind.)
  8. Jun 20, 2011 #7
    Hi
    Thanks for clearing that up!
    Is there a chart similar to the psychrometrics chart that describes this ice to vapour transition in the presence of air under difference conditions?
    Also, how come we have boiling and evaporation for liquid to vapour transition? Do we have two types of transitions for solid to liquid or solid to ice?
    Thanks
  9. Jun 20, 2011 #8
    Mapes
    Perhaps you can make one!
    Boiling is a special case of evaporation in which the vapor pressure has exceeded the atmospheric pressure.
  10. Jun 20, 2011 #9
    Is melting more synonymous to boiling or more to evaporation? What about sublimation?
  11. Jun 21, 2011 #10
    Mapes
    What do you think? Melting is defined as a change of state from what to what?
  12. Jun 21, 2011 #11
    MATLABdude
  13. Jun 21, 2011 #12
    From solid to liquid? So I guess closer to evaporation?
  14. Jun 22, 2011 #13
    Mapes
    I'm not sure why a solid-to-liquid transition would be more like a liquid-to-gas transition and less like a solid-to-gas transition... They all seem pretty distinct.
  15. Jun 30, 2011 #14
    I can see how this question is kind of weird. I was thinking that, in boiling there is bubble/phase change in the bulk of the liquid, so I'm just wondering if in melting does it occur from the outside inwards or within the bulk of the solid.
  16. Jun 30, 2011 #15
    Mapes
    Boiling and melting will both generally occur preferentially closer to the heat source (assuming ample possible nucleation sites).
  17. Jul 3, 2011 #16
    Hi
    So am I correct to say that in boiling, the liquid closer to the heat source vaporizes first (i.e. from the outside inwards) and the bubble in the bulk of the liquid results from these vapors from the outside rising up?
    Thanks very much
  18. Jul 4, 2011 #17
    Mapes
    Generally, yes.
Loading...
Similar Threads for Solid Vapour Coexistence
Split Hopkinson pressure bar data
Solid-liquid Equilibrium via EOS
