How does molecular shape affect boiling point in organic compounds?
In summary, the factors that determine solubility and boiling point in organic compounds are intermolecular forces (IMF) such as dipole-dipole interactions and hydrogen bonding. Solubility is mainly influenced by the IMF between solvent-solute molecules, while boiling point is affected by the IMF between the same molecules. Bond strength in chemical bonds does not directly affect boiling point, but it can indirectly influence it through IMF. Hydrogen bonding, although relatively weak individually, can have a significant impact on both solubility and boiling point due to the large number of bonds present in a substance.
staka
23
In organic chemistry,
What causes a compound to be more soluble than others?
What causes a compound to have a higher boiling point than others?
I think the more molecular mass a compound has, the higher boiling point.
However, methoxymethane and ethanol both have the same molecular mass but in different shape. What causes it to have a higher boiling point?
Whichever can be broken apart easier will have a lower boiling point, I believe. Look for differences in bond strength in the molecules, e.g double-bond vs a single, etc.
Methoxymethane and ethanol are both single bonded compounds.
Ethanol has OH on its own.. does it have higher or lower boiling point than methoxymethane?
Since the bonds are all single, in this case, you'll mainly want to look at Intermolecular Forces (IMF). Look for things such as differences in hydrogen bonding (H to a O,N,F - requires a lot of energy to break). (The -OH group as well)
oh alright, thanks. so higher boiling point in ethanol.
I believe so, no problem.
Bonds and their strength have nothing to do with the boiling point! Boiling point and melting point depend on the intermolecular forces, not on the internal structure of the molecule.
Molecules are not broken apart during boiling, they are separated but intact.
So which will have a higher boiling point?
Think in terms of intermolecular bonds.
What types do you know? Which are the strongest?
Why water has a very high boiling point?
Oh hydrogen bonding significantly affects it.. much higher boiling point in ethanol than of methoxymethane.
Wasn't that hard.
I mentioned IMF in mypost. And according to my chemistry professor, bond strength makes a difference in boiling point as well.
Ask for examples.
Maybe prof. meant bond-strength as in dipole-dipole, hydrogen, etc.?
Dipole-Dipole moments and hydrogen bonding is a form of intermolecular force. Bond strength is between 2 atoms in a chemical bond. There is no way they can be used as synonyms.
I hear people say hydrogen bonds alone are weak, so it seems it is used that way in conversation.
Well, perhaps so, but for now it's probably easier for you to distinguish between formal bonds (covalent/ionic) and intermolecular forces, lest you get confused!
while checking out for the factors that affect the parameter, we go for the one that has maximum effect, not towards which having least.
solubility is mainly determined by the dipole dipole interactions, hydrogen bonding.
while boiling point is more or less dependent on same parameters too.
in solubility the interactions with the solvent-solute molecules is imp.
while in boiling point its between same molecules.
Individual hydrogen bonds may be relatively weak but a larger number of such bonds is anything but weak. Have you ever seen two pieces of glass be stuck together because of water between the pieces. It is virtually impossible to lift one glass from the other without shattering the glass.
1. What is solubility?
Solubility refers to the ability of a substance, known as the solute, to dissolve in another substance, known as the solvent, to form a homogenous mixture. It is typically measured in terms of the amount of solute that can dissolve in a given amount of solvent at a certain temperature.
2. How does temperature affect solubility?
In general, as temperature increases, the solubility of solids in liquids also increases. This is because higher temperature means that the particles in the solvent have more energy, allowing them to break apart the bonds of the solute more easily. However, the opposite is true for gases in liquids, where solubility typically decreases as temperature increases.
3. What is the boiling point of a substance and how is it related to solubility?
The boiling point is the temperature at which a substance changes from a liquid to a gas. It is influenced by factors such as atmospheric pressure and the strength of intermolecular forces. Generally, substances with higher boiling points also tend to have higher solubility in water, as they have stronger intermolecular forces and are less likely to evaporate.
4. How does polarity affect solubility?
Polarity refers to the distribution of charge within a molecule. Substances with similar polarities tend to be more soluble in each other, while substances with opposite polarities are less likely to mix. For example, polar substances like water are able to dissolve other polar substances such as salt, while nonpolar substances like oil are not soluble in water.
5. Can the solubility of a substance change with pressure?
In most cases, pressure does not have a significant effect on the solubility of solids and liquids in liquids. However, pressure can have a significant impact on the solubility of gases in liquids. When the pressure on a gas increases, its solubility in a liquid will also increase. This is why carbonated drinks will release more gas when opened at high altitudes, where the air pressure is lower.
12K
  • Other Physics Topics
  • Chemistry
