Homework Help: Solution to first order ODE
  1. Mar 4, 2014 #1
    Can anyone point out where I have gone wrong with this?
    Verify that the given function is a solution of the differential equation.
    [tex]y' -2ty =1[/tex] [tex]y= e^{t^2}\int^t_0 e^{-s^2}ds+e^{t^2}[/tex]
    3. The attempt at a solution
    The steps I have taken are the following:
    i) Evaluate integral in expression for y
    ii) Differentiate the expression for y
    iii)Substitute these values into [tex]\frac{dy}{dt}-2ty=1[/tex]
    i)Evaluate the integral
    [tex]\int^t_0e^{-s^2}ds[/tex]
    by substitution:
    [tex]u=s^2[/tex]; [tex]ds=\frac{1}{-2s}du[/tex]
    [tex]\frac{1}{-2s}\int^t_0e^{u}du = \left[\frac{e^{-s^2}}{-2s}\right]^t_0 =\frac{e^{-t^2}}{-2t}[/tex]
    ii)Differentiate expression for y
    [tex]y=e^{t^2}\cdot \frac{e^{-t^2}}{-2t}+e^{t^2}[/tex]
    [tex] y=e^{t^2}-\frac{1}{2}t^{-1}[/tex]
    [tex]y'=2te^{t^2}+\frac{1}{2}t^{-2}[/tex]
    iii) Substitute these into [tex]y'-2ty=1
    [tex]2te^{t^2}+\frac{1}{2}t^{-2} -2t(2te^t{2}+\frac{1}{2}t^{-2})[/tex]
    [tex]2te^{t^2}+\frac{1}{2}t^{-2}-4t^2e^{t^2}-t^{-1}[/tex]
    Which is not what is required.
  3. Mar 4, 2014 #2
    Hi jellicorse!
    The quoted step is incorrect. There exists no antiderivative for ##e^{-x^2}##. While evaluating the integral, you took ##s## outside the integral but ##s## is a function of ##u## so what you did is not valid.
    For the given problem, you have to differentiate the given function using Fundamental Theorem of Calculus. Can you find the derivative wrt t for:
    $$\int_0^t e^{-s^2}\,ds$$
  4. Mar 4, 2014 #3
    Thanks a lot Pranav!
    I need to go and revise the Fundamental Theorem of Calculus again to check...
  5. Mar 4, 2014 #4
    Oh, I forgot. Welcome to PF! :smile:
  6. Mar 4, 2014 #5
    Thanks, Pranav!
    I see that comes to [tex]e^{-t^2}[/tex] according to the Fundamental Theorem of Calculus... I am getting a bit rusty on that so need to revise it a bit!
  7. Mar 4, 2014 #6
    Your welcome. :)
    Yes. :approve:
  8. Mar 4, 2014 #7
    hilbert2
    It sure does exist, and it's called the error function, but you can't represent it in terms of elementary functions.
    http://en.wikipedia.org/wiki/Error_function
  9. Mar 4, 2014 #8
    Yes, that's what I meant, sorry for the confusion. :redface:
Have something to add?
Draft saved Draft deleted
