Solutions to Newtonian gravity
In summary: Hold on, this isn't right.You're right, it's not right. You need to first divide by r^2. \frac{\partial}{\partial t}(\vec{r}\times\dot{\vec{r}}) = \vec{r}\times\ddot{\vec{r}} = \vec{r}\times\vec{r}\times\ddot{\vec{r}} = \vec{r}\times r^3.
llamascience
I've only just completed high school, but I have a decent grasp on basic undergrad maths/physics. After hours and hours of paper and mental calculations, I still can't see a way of solving Newton's law of gravitation for the path of a body given inital position/velocity i.e. the second order non-linear differential equation r'' = -GM/(r^2).
Can somebody please put my mind at ease by telling me that it cannot be done or showing me how. T'would be much appreciated as I am getting sick of pages that go from Newton's law to conic sections in one jump.
It can be done; but, it's rather long. The first thing you need to keep in mind is that Newton's 2nd law is a vector equation. So, what you should have there is [itex]\frac{d^2\vec{r}}{dt^2}} = \frac{-GM}{r^2}\hat{r}[/itex], where [itex]\vec{r} = r\hat{r}[/itex]. Then, remember that since the radial direction changes with angular coordinates, [itex]\hat{r}[/itex] has a non-zero time derivative. From these considerations and a good choice of angular coordinates, you should be able to separate this down to two equations in r and [itex]\phi[/itex] and a constraint that all motion will be in a plane. From the two equations, you should be able to get a differential equation for r and one that let's you determine [itex]\phi[/itex] once you know r. The r equation can be solved by changing variables to [itex]u = \frac{1}{r}[/itex]. Hope this helps.
Try an energy approach (for the 1 dimensional case)
[tex](\frac{dx}{dt})^2 = \frac{C}{x}[/tex]
Squareroot both sides, separate the variables and it should be solvable.
Wait up there, is that KE = PE??
Essentially. More Correct would be KE + PE = Constant, but solving for the C in the expression I gave shouldn't be hard.
Maybe it's 4 in the morning or maybe I am just missing the point entirely, but is C supposed to be a constant? Please explain in more detail if possible.
Yes it is supposed to be a constant.
Suppose your particle starts from rest, at a distance x_0. Then you have
[tex]
\frac{1}{2}mv^2 - \frac{GM_1M_2}{x} = -\frac{GM_1M_2}{x_0}[/tex]
You can then reduce it into the form
[tex]
v^2 = A + \frac{B}{x}
[/tex]
Where A and B are constants, and then solve by separating x and t.
I cannot do both, since it can be done, and right now I can't show you how. I may be able to do it, say, tomorrow. Would you like to know the most general approach? Are you comfortable with vectors, just the basic differentiation and stuff like that?
i'd hope so, or i did not deserve a 97% in my calc course :P
if you don't mind doing so, id like a detailed explanation of how to go about this. its been haunting my mind for the past year and all the replies I've been given have been helpful, but unsatisfactory
I'll start with very basic stuff, since I don't know what you know and what approach you want. We'll proceed in small steps.
The general eqn of motion would be mr'' = -GMmr/r^3. Can you prove from this that the motion is in a plane, and also that there is a conserved vector, that is, a vector whose magnitude and direction is constant?
For this, you don't require the inverse square law, but any central force, that is, a force of the form f(r)r. Note that r is the magnitude of r.
[Hint (may be ignored): d/dt(rXr') = rXr''.
yer, the vector product of the position vector and the velocity is conserved and as this is always perpendicular to the velocity, the motion must be in plane
(EDIT: I would like a one line justification for your above statement. That is to say, why is the product of the posn vector and the velo conserved?)
Excellent. I'll just elaborate on this a bit. To review what you've said, we got,
d/dt(rXmv) = 0 => rXp = L, where p = mv is the linear momentum, and L is the constant vector. L is called the angular momentum about the origin.
Since r.L = 0, r must be always perp to L, and so r must lie in a plane.
(I've got to run now, but we'll finish off by next one or two posts.)
aahhh, gotcha. i knew id seen a similar form before, just couldn't put my finger on it
we never covered angular mechanics to any significant detail in TEE physics and for some reason vectors were practically left out of the course. still, i understand the basics from outside reading
JUSTIFICATION: so as you pointed out[tex]\frac{\partial}{\partial t}(\vec{r}\times\dot{\vec{r}}) = \vec{r}\times\ddot{\vec{r}}[/tex]
so [tex]\frac{\partial}{\partial t}(\vec{r}\times\dot{\vec{r}}) = \vec{r}\times\normalfont{f(r)}\hat{\vec{r}} = f(r)\vec{0} = \vec{0}[/tex]
thus the vector [tex]\vec{r}\times\dot{\vec{r}}[/tex] is time-invariant. then, like you say the position and velocity are perp. to this so the motion is planar
One minor correction here: Those are total derivatives wrt time, not partial derivatives.
Note that angular momentum L is necessarily conserved whenever the magnitude of the force vector is a function of the magnitude of the distance vector only and the force vector is directed along or against the distance vector. This is called a central force problem.
It is better to work in the center of mass frame rather than a frame with the Sun at the origin. Total energy (kinetic + potential), angular momentum, and linear momentum are all conserved in this frame. While linear momentum is tautologically zero in the center of mass frame, that total energy and angular momentum are constants of motion is the key to solving the problem.
Hi D H,
Thanks for correcting llamascience on the use of the partial derivatives. This student has just finished high school and I'm trying to satisfy his/her curiosity in the simplest possible way. Right now, I don't think introduction of reduced mass will be very fruitful. Anyway, he has to solve the same equations for that. So, for the present, we'll take the origin at the Sun and the Earth to be very light compared to Sun.
Have a look at post #10 for central forces.
(Hi llamascience, be back with you.)
I hope you now that angular momentum remain conserved during any motion in gravitational field thus
r*m*v=constant=initial given to it
G*mass of earth*massof body/r+0.5 *m*v*v=constant=initial one...
try if this can help
actually, for the sake of my picking up something new here, could both of you explain your methods simultaneously?
dont worry about my being just out of high school (australia btw, just to avoid confusion). i don't mean to sound over-confident, but like i say; I've read a lot of university level maths and understand a great deal of it, especially in physics related areas like vector calculus, differential equations etc.
still, continue with your method :)
This is not quite right. The magnitude of angular momentum is [itex]mrv\sin\theta[/itex], where [itex]\theta[/itex] is the angle between [itex]\vec{r}[/itex] and [itex]\vec{v}[/itex]. In the most general case, there is no reason to think that [itex]\vec{r}[/itex] and [itex]\vec{v}[/itex] are always perpendicular.
also, please explain why the partial derivative and total derivative with respect to time should be any different when r is dependent only on the one variable: t.
i know that in the general case this could create confusion with solving a PDE, but how will the choice of differential affect the result in this trivial case?
well i never said that v,r to be treated as scalers if i just didnt put an arrow
what i meant was cross product of velocity and position vector
Contd. From post #12.
To simplify, let h = L/m, so that h = rXv and r= re, where e is the unit vector in the direction of r. I will leave certain simplifications to you.
Note that e.de/dt = 0 . (Can you say why? Hint: magnitude of e is constant.)
r = re => v = dr/dt = rde/dt + dr/dt e =>
h = rXv = r^2 eXde/dt. --- (1) (I leave the simplification to you.)
d/dt(vXh) = (dv/dt)Xh = -(GM/r^2)eXh = -GMe X (e X de/dt) = GMde/dt. (using (1).)
So, now we have got an integrable eqn:
d/dt(vXh) = GMde/dt =>
vXh = GMe + A. where A is a constant vector. Taking the scalar product of r with both sides, we get,
r.(vXh) = GM(r.e) + r.A. But r.(vXh) = h^2. (Prove it.) So,
h^2 = GMr + rAcos(theta) =>
r = (h^2/GM)/[1 + (A/GM)cos(theta)], which is the standard form for a conic section:
r = a/(1 + ecos(theta)). (This e denotes the eccentricity.)
I have used only elementary properties of vectors to find the path. The orbit around an inverse square central force is in general a conic section. You can choose the x-axis along A.
What you had wanted is to be able to solve for the path given ri and vi. Well, riXvi = h, and from ri you can find ri and thetai. So, you can know the value of r at any theta.
Getting the r and theta given the t only requires a more advanced treatment. I can give you the formulae, but you'll be doing it soon, I guess.
ill just go through each bit you said to do myself and show you my working. if you see anywhere i can improve in efficiency, please tell :)
the magnitude of e is constant so:
[tex]0 = \frac{d}{dt}\left|\vec{e}\right| = \frac{d}{dt}\sqrt{\vec{e}.\vec{e}} = \frac{2\vec{e}.\frac{d\vec{e}}{dt}}{2\sqrt{\vec{e}.\vec{e}}}[/tex]
therefore:
[tex]\vec{e}.\frac{d\vec{e}}{dt} = 0[/tex]
then
[tex]\vec{h} = \vec{r}\times\vec{v} = r\vec{e}\times\left(r\frac{d\vec{e}}{dt}+\frac{dr}{dt}\vec{e}\right) = r\vec{e}\times r\frac{d\vec{e}}{dt}+r\vec{e}\times\frac{dr}{dt}\vec{e} = r^{2}\vec{e}\times\frac{d\vec{e}}{dt}+r\frac{dr}{dt}\vec{e}\times\vec{e} = r^{2}\vec{e}\times\frac{d\vec{e}}{dt}[/tex]
and
using the scalar triple product:
[tex]\vec{r}\cdot\left(\vec{v}\times\vec{h}\right) = \left(\vec{r}\times\vec{v}\right)\cdot\vec{h} = \vec{h}\cdot\vec{h} = h^{2}[/tex]
finally, thank you so much for explaining this step-by-step. this method made so much more sense than what i was attempting, using changes of variable, separation, etc
I am impressed in the way you have walked in step with me. Your derivations are all correct -- the ones I'd left for you to prove.
A note of caution, though. This method of getting an integrable vector eqn and getting the path directly, worked only because it was an inverse square law, For example, I don't think you'll get such an integrable vector eqn in an inverse cube law. This is because in inverse square law, in addition to energy and angular momentum being conserved, there is a third vector which is conserved. It’s called the Runge-Lenz vector, or simply the Lenz vector, even though it was originally discovered by Laplace.
Care to venture your opinion as to what that vector is?
well, it must have something to do with [tex]\vec{r}[/tex], being conserved only for inverse square fields
it might come to me after a while, but please enlighten me
actually, is it the constant vector of integration we produced?
I don't even want to know what you meant by that! But what did you mean?
You got it. Very good. What we produced will probably be have to be multiplied by m^2, but that's just a matter of definition.
By this I meant that I believed the Runge-Lenz Vector would have to be defined in terms of [tex]\vec{r}[/tex], given that it is conserved in all force fields with the inverse square property and as you said; not inverse cube.
A: How do you determine the magnitude of this vector? (I'm assuming we still define it as lying along the positive x-axis
and
B: What properties of the path (other than eccentricity) does this quantity describe?
A. Look at the step when A appeared. You can put the initial values of r, h and e. Also, perhaps geometrically.
B. The line of action of A is along the axis of the conic section. There may be some other salient properties which I may have forgotten. Will look up both and tell you.
(Sorry for the late reply.)
That’s it -- more or less. The fact that there is such a vector A shows that the inverse square law has some special properties. You’ll come across it soon, I think.
The direction of A is along the radius vector toward the perihelion of the orbit. That’s one more thing you can prove. (So, it’s along the axis of the conic section which is the orbit.) And find its magnitude in terms of G, M etc.
1. What is Newtonian gravity?
Newtonian gravity is a physical theory developed by Sir Isaac Newton in the 17th century to explain the force of gravity between objects. It states that every object in the universe exerts a force of attraction on every other object, and this force is directly proportional to the masses of the objects and inversely proportional to the square of the distance between them.
2. How does Newtonian gravity differ from Einstein's theory of general relativity?
Newtonian gravity is a classical theory that describes gravity as a force acting between masses, while Einstein's theory of general relativity is a modern theory that explains gravity as the curvature of spacetime caused by the presence of massive objects.
3. Can Newtonian gravity be used to explain the motion of objects in the universe?
Yes, Newtonian gravity is still a highly accurate and useful theory for explaining the motion of objects in the universe, especially for everyday situations where the effects of gravity are not extreme.
4. What are some limitations of Newtonian gravity?
Newtonian gravity does not fully explain the behavior of objects at very high speeds or in strong gravitational fields, such as near black holes. It also does not account for the effects of dark matter and dark energy, which are important components of the modern understanding of the universe.
5. How is Newtonian gravity used in practical applications?
Newtonian gravity is used in many practical applications, such as calculating the trajectories of spacecraft, predicting the orbits of planets and other celestial bodies, and determining the forces acting on structures on Earth. It is also the basis for many engineering calculations and designs.
  • Classical Physics
  • Beyond the Standard Models
