kmarinas86
- 979
- 1
http://www.hostsrv.com/webmab/app1/MSP/quickmath/02/pageGenerate?site=quickmath&s1=equations&s2=solve&s3=basic
FACT: THIS IS HELPS ME!
Matlab's more numerical.Jeff Reid said:What about matlab? I had the impression that this tool could solve quite a few type of equations.
To solve a basic equation with one variable, the first step is to isolate the variable on one side of the equation by using inverse operations. Then, perform the same operation on both sides of the equation until the variable is isolated. Finally, check your solution by plugging it back into the original equation.
If there are variables on both sides of the equation, start by combining like terms on each side. Then, use inverse operations to isolate the variable on one side of the equation. Continue to solve using the same steps as a basic equation with one variable.
No, different types of equations may require different methods to solve. For example, quadratic equations may require factoring or using the quadratic formula. It is important to identify the type of equation and use the appropriate method to solve it.
If there are fractions or decimals in the equation, start by clearing them by multiplying both sides of the equation by the common denominator. Then, follow the same steps as solving a basic equation with one variable.
If you are unable to solve the equation, it may have no solution or an infinite number of solutions. This may happen if the equation is inconsistent or if the variable cancels out on both sides. In these cases, it is important to check your steps and make sure there are no errors. If there are no errors, then the equation has no solution or infinite solutions.
