Solve differential equation
  1. Jan 28, 2012 #1
    DryRun
    The problem statement, all variables and given/known data
    http://s1.ipicture.ru/uploads/20120128/U1SBMa6O.jpg
    The attempt at a solution
    I expanded the equation and got:
    [tex]\frac{dy}{dx}=\frac{ylny-ylnx+y}{x}[/tex]
    I can't use the method of separation of variables, nor is this a homogeneous equation. It's not a 1st order linear ODE nor in the Bernoulli format. I'm stuck.
  3. Jan 28, 2012 #2
    ehild
    Hi sharks,
    The right side of the equation is function of y/x. Try new variable y/x=u.
    ehild
  4. Jan 28, 2012 #3
    DryRun
    Hi ehild!
    So, i guess this is a homogeneous equation.
    [tex]\frac{dy}{dx}=u(lny-lnx+1)[/tex]
    I'm supposed to eliminate all y and x on the R.H.S. and replace by u only.
    [tex]\frac{dy}{dx}=u(lny-lnx+1)=u(lnu+1)=ulnu+u[/tex]
    From [itex]y=ux[/itex], [itex]\frac{dy}{dx}=u+x\frac{du}{dx}[/itex]. Then, [itex]u+x\frac{du}{dx}=ulnu+u[/itex].
    So, [itex]x\frac{du}{dx}=ulnu[/itex]
    [tex]\frac{dx}{x}=\frac{1}{ulnu}\,.du[/tex]
  5. Jan 28, 2012 #4
    ehild
    And what is dy/dx in terms of u and x?
    ehild
  6. Jan 28, 2012 #5
    DryRun
    I have edited my previous post but then i'm stuck at integrating the R.H.S. of: [tex]\int \frac{dx}{x}=\int \frac{1}{ulnu}\,.du[/tex]
    [tex]lnx=\int \frac{1}{ulnu}\,.du[/tex]
    If i consider integrating [itex]1/u[/itex] then i get [itex]lnu[/itex].
  7. Jan 28, 2012 #6
    ehild
    1/u is the differential of ln(u). So the integrand is of form 1/ln(u) (lnu)'
    I just can not understand what you did.
    ehild
  8. Jan 28, 2012 #7
    DryRun
    The integration result would then be [itex]ln(lnu)+lnA[/itex], where lnA is the arbitrary real constant of integration.
    Therefore, [itex]lnx=ln(lnu)+lnA[/itex] or [itex]x=Alnu[/itex] or [itex]\frac{x}{A}=lnu[/itex]
    [tex]\frac{x}{A}=ln\frac{y}{x}[/tex]
    [tex]\huge e^\frac{x}{A}=\frac{y}{x}[/tex]
    So, the final answer is (i'm using big font to make the power fraction more visible):
    [tex]\huge y=xe^\frac{x}{A}[/tex]
    Is that correct?
  9. Jan 28, 2012 #8
    ehild
    Try to substitute it back into the original equation.
    ehild
  10. Jan 28, 2012 #9
    DryRun
    Yes, i get the same L.H.S and R.H.S. that is,
    [tex]\huge \frac{xe^\frac{x}{A}}{A}+e^\frac{x}{A}[/tex]
    So, i assume this is the proof. Thanks, ehild.:smile:
  11. Jan 28, 2012 #10
    ehild
    You are welcome:smile: Remember that y/x substitution.
    ehild
