Solve the definite integral?
In summary, the problem is to find the integral of x/sqrt(x²+1) with upper limit of sqrt 3 and lower limit of 0. By substituting u as x²+1, and using the integration formula 1/2∫ u^(-1/2)du, we get the result of 1 for the integral. This can also be achieved by changing the limits of integration for the same substitution.
noname1
134
The problem is: ∫ x / sqrt(x²+1)
Upper limit is sqrt 3
lower limit is 0
I choose u as x²+1
1/2du = dx.x
1/2∫ 1/u^1/2 =
1/2∫ u^(-1/2)du =
1/2 ∫ U^(1/2) / (1/2) =
(1/2) * (2/1) * u^1/2 = 1 * u^(1/2)u = (sqrt3)² + 1 = 4
u = 0² + 1 = 1
than i substituted
1 * 4^1/2 - 1 * 1^(1/2) =
1 * 2 - 1 * 1 =
2 - 1 = 1
is this correct?
lower limit is 0
I choose u as x²+1
1/2du = dx.x
1/2∫ 1/u^1/2 =
1/2∫ u^(-1/2)du =
u = 0² + 1 = 1
than i substituted
1 * 2 - 1 * 1 =
2 - 1 = 1
is this correct?
Yes. Here's another way that changes the limits of integration for the same substitution.
[tex]\int_0^{\sqrt{3}} \frac{x~dx}{\sqrt{x^2 + 1}}[/tex]
[tex]= \frac{1}{2}\int_1^4 u^{-1/2}~du~=~u^{1/2}|_1^4[/tex]
[tex]=2 - 1 = 1[/tex]
What is a definite integral?
A definite integral is a mathematical concept used to calculate the area under a curve or the net change in a function over a specific interval. It is represented by the symbol ∫ and has a lower and upper limit of integration.
How do you solve a definite integral?
To solve a definite integral, you can use various methods such as the power rule, substitution, integration by parts, or trigonometric substitution. You can also use numerical methods like the trapezoidal rule or Simpson's rule to approximate the value of the integral.
What is the purpose of solving a definite integral?
The main purpose of solving a definite integral is to find the area under a curve or the total change in a function over a specific interval. This can be useful in many real-life applications, including physics, engineering, and economics.
What is the difference between a definite integral and an indefinite integral?
The main difference between a definite integral and an indefinite integral is that a definite integral has specific limits of integration, while an indefinite integral does not. A definite integral gives a numerical value, while an indefinite integral gives a function as the result.
What are the common mistakes to avoid when solving a definite integral?
Some common mistakes to avoid when solving a definite integral include forgetting to include the constant of integration, making errors in algebraic manipulation, and using the wrong method for integration. It is also important to be careful with the limits of integration and to double-check the final answer for accuracy.
