Solving an Exponent Equation: How to Prove the Two Solutions?
  • MHB
  • Thread starter anemone
  • Tags
    Exponent
In summary, we are trying to solve the equation $5^x+5^{x^2}=4^x+6^{x^2}$ in the set of real numbers. After some initial attempts, we use the Mean Value Theorem to show that for every $x$, there is a $4<c<5$ and a $5<d<6$, such that $xc^{x-1}=x^2d^{x^2-1}$. By analyzing this equation, we can conclude that $x=0$ and $x=1$ are the only solutions to the original equation. This is proven by considering the cases where $x<0$, $x=0$, $0<x<1$,
anemone
MHB
POTW Director
3,883
115
Hi MHB,
Problem:
Solve in the set of real numbers the equation $5^x+5^{x^2}=4^x+6^{x^2}$.
Attempt:
At first glance, we can tell $x=0, 1$ would be the two answers to the problem but how do we prove these two are the only answers?
I think this problem must have something to do with the Mean Value Theorem, because if we let $f(a)=a^x$, we know the function of $f$ is continuous and differentiable on $[4, 5]$, so by the Mean Value Theorem, we have
$f'(c)=\dfrac{5^x-4^x}{5-4}=5^x-4^x$ where $4<c<5$.
Similarly, by letting $g(a)=a^{x^2}$, we know the function of $g$ is continuous and differentiable on $[5, 6]$, so by the Mean Value Theorem, we have
$g'(d)=\dfrac{6^x-5^x}{6-5}=6^x-5^x$ where $5<d<6$.
Recall that we are given $5^x+5^{x^2}=4^x+6^{x^2}$, that means $f'(c)=g'(d)$.
But if we are to differentiate the functions of $f$ and $g$ w.r.t. $a$, we get
$f(a)=a^x$
$f'(a)=xa^{x-1}$
$g(a)=a^{x^2}$
$g'(a)=x^2a^{x^2-1}$
$\therefore f'(c)=xc^{x-1}$$\therefore g'(d)=x^2d^{x^2-1}$
By equating the two derivatives we get
I don't know how to continue from there hence any help is appreciated!:)
Very creative. :)
What you have, is:
$$\text{For every $x$, there is a $4<c<5$ and a $5<d<6$, such that }xc^{x-1}=x^2d^{x^2-1}$$
Now suppose x<0. Then the LHS is negative while the RHS is positive.
So there are no solutions with x<0.
Suppose x>0, then we can divide by x and take the $\ln$ from both sides.
\begin{array}{}
c^{x-1}&=&x d^{x^2-1}\\
(x-1) \ln c &=& \ln x + (x^2-1) \ln d\\
(x-1) ((x+1)\ln d - \ln c) + \ln x &=& 0
\end{array}
Since d > c that means that $(x+1)\ln d - \ln c > 0$.
Now if 0 < x < 1, the LHS is negative, which is a contradiction.
And if x > 1, the LHS is positive, which is again a contradiction.
Therefore $x=0$ and $x=1$ are the only solutions.
I like Serena said:
Very creative. :)
What you have, is:
\begin{array}{}
\end{array}
Awesome, I like Serena! Thank you so much for the easy to understand reasoning to show that those two $x$ values are the only solutions to the problem.
Thank you!:eek:
1. How do I solve an exponent equation?
To solve an exponent equation, you can use the rules of exponents to simplify the expression. This may involve using properties such as the power rule, product rule, or quotient rule. Once the expression is simplified, you can equate it to the given value and solve for the unknown variable.
2. What are the basic rules of exponents?
The basic rules of exponents include the power rule, product rule, quotient rule, zero exponent rule, and negative exponent rule. The power rule states that when a number is raised to a power, you can multiply the exponents. The product rule states that when multiplying two numbers with the same base, you can add the exponents. The quotient rule states that when dividing two numbers with the same base, you can subtract the exponents. The zero exponent rule states that any number raised to the power of zero is equal to 1. The negative exponent rule states that a negative exponent can be rewritten as the reciprocal of the base raised to the positive exponent.
3. How do I know when to use the rules of exponents?
You can use the rules of exponents when simplifying expressions with exponents or when solving an exponent equation. These rules help to make solving exponent problems easier and more efficient.
4. Can I solve an exponent equation without using the rules of exponents?
In some cases, it may be possible to solve an exponent equation without using the rules of exponents. This may involve factoring or using other algebraic techniques. However, using the rules of exponents can often provide a quicker and more straightforward solution.
5. Are there any tips for solving exponent equations?
One tip for solving exponent equations is to keep track of the rules of exponents and use them consistently throughout the problem. It can also be helpful to simplify the expression as much as possible before solving for the unknown variable. Additionally, it is important to check your solution by plugging it back into the original equation to ensure it satisfies the given value.
  • Calculus
  • Calculus
  • Calculus
