Solve x & y: x2 + (√8)x*sin[(√2)xy] +2 = 0
  • Thread starter kscplay
In summary: That's genius! I'm glad I didn't miss out on reading this :smile::smile:There was a typo, I corrected it in post #7. The square should not be there in my first equation. Correctly it is x+\sqrt{2}\sin(\sqrt{2}xy)=0
kscplay
23
Solve for x and y:
Other than decomposing the root 8 i don't know what else to do. any hints? thanks.
Hi kscplay,
Transform the equation into the form (x+a)2+b=0
ehild
kscplay said:
Solve for x and y:
QUOTE]
ehild said:
Hi kscplay,
ehild, I don't see how this will lead anywhere, due to the presence of x in the sine factor.
I meant (x+√2sin[√2xy])2=-2+2sin2[√2xy]).
The left hand side can not be negative. The right hand side ?...ehild
this might be a silly question, but wouldn't you first isolate y?
That could be also a way to find the solution. But I would look at the right hand side of my equation and see if it can be positive.ehild
If we isolate y we get [tex]y=\frac{1}{\sqrt{2}x}\arcsin(-\frac{x^2+2}{2\sqrt{2}x})[/tex] The argument of arcsin has to be in the range [-1,1]. What does it mean for x?
My method of transforming the equation to [itex](x+\sqrt{2}\sin(\sqrt{2}xy)^2=-2+2sin^2(\sqrt{2}xy)[/itex] shows that the left hand side can not be negative, the right-hand side can not be positive so both have to be zero.
[tex]x+\sqrt{2}\sin(\sqrt{2}xy)=0[/tex]
[tex]\sin^2(\sqrt{2}xy)=1 [/tex]
two equations, two unknowns...
ehild
My method of transforming the equation to (x+√2sin[√2xy])^2=-2+2sin^2[√2xy]) shows that the left hand side can not be negative, the right-hand side can not be positive so both have to be zero.
[tex]x+\sqrt{2}\sin^2(\sqrt{2}xy)=0[/tex]
ehild
:smile:
There was a typo , I corrected it in post #7. The square should not be there in my first equation. Correctly it is [tex]x+\sqrt{2}\sin(\sqrt{2}xy)=0[/tex]
ehild
That's a smart idea. Thanks ehild :)
You are welcome, kscplay.:smile:
The other way, jkristia suggested would work too.
[tex]y=-\frac{1}{\sqrt{2}x}\arcsin \left( \frac{x^2+2}{2\sqrt{2}x} \right)[/tex]
The magnitude of the argument of the arcsin function can not exceed 1:
[tex] \left| \frac{x^2+2}{2 \sqrt{2} x} \right| \leq 1[/tex]
The function
[tex]
\frac{x^2+2}{2\sqrt{2}x}[/tex] has extrema at x=±√2, minimum (1) for positive x and maximum (-1) for negative x. Only these values are allowed for x.
ehild
1. What is the equation "x2 + (√8)x*sin[(√2)xy] +2 = 0" trying to solve?
The equation is trying to solve for the values of x and y that satisfy the given equation.
2. What are the steps to solve the equation "x2 + (√8)x*sin[(√2)xy] +2 = 0"?
The steps to solve the equation are as follows:
1. Move all constants to one side of the equation and all variables to the other side.
2. Use the quadratic formula to solve for x.
3. Substitute the value of x into the equation and solve for y.
4. Check the solutions by plugging them back into the original equation.
3. Can the equation "x2 + (√8)x*sin[(√2)xy] +2 = 0" be solved algebraically?
Yes, the equation can be solved algebraically by following the steps mentioned in the previous question.
4. Are there any restrictions on the values of x and y in the equation "x2 + (√8)x*sin[(√2)xy] +2 = 0"?
Yes, there may be restrictions on the values of x and y depending on the given equation. In this equation, the values of x and y must make the expression under the square root positive, otherwise the equation will not have real solutions.
5. Can the equation "x2 + (√8)x*sin[(√2)xy] +2 = 0" have more than one solution?
Yes, the equation can have more than one solution. In fact, quadratic equations can have up to two real solutions.
