zeion
- 466
- 1
Use your knowledge of exponents to solve
[tex] \frac{1}{2^x} > \frac{1}{x^2} [/tex]
[tex] x^2 > 2^x [/tex]
Then I am stuck.
I know they intersect at x = 2.
micromass said:Try to find out when the equality holds. Let's say they hold at a and b. This will give you regions [tex] ]-\infty,a[, ]a,b[, ]b,+\infty[ [/tex]. From any region, pick a point and check if the inequality is satisfied at that point. If so, then that region is part of the solution.
zeion said:The Attempt at a Solution
Then I am stuck.
An inequality with an exponent is a mathematical statement that compares two quantities using an exponent. An exponent is a number that represents how many times a base number is multiplied by itself. Inequalities with exponents involve comparing the value of an expression with an exponent to another expression with an exponent.
To solve an inequality with an exponent, you will first need to isolate the variable with the exponent on one side of the inequality sign. Then, you can use the rules of exponents to simplify the expression. Finally, you can solve for the variable by using inverse operations.
The rules of exponents are a set of mathematical rules that govern how exponents can be manipulated. These rules include the product rule, quotient rule, power rule, and zero and negative exponent rules. These rules can be used to simplify expressions with exponents and solve inequalities with exponents.
Yes, you can use a calculator to solve an inequality with an exponent. Most scientific calculators have a button for exponents, and some even have a button specifically for inequalities. However, it is important to understand the steps and rules involved in solving an inequality with an exponent in order to use a calculator effectively.
Some common mistakes when solving an inequality with an exponent include forgetting to apply the rules of exponents, not isolating the variable with the exponent, and using incorrect inverse operations. It is also important to pay attention to the direction of the inequality sign and to be careful with negative exponents.
