How can I find the Eigenvector for a 3x3 matrix?
  • Thread starter Saladsamurai
  • Tags
    3x3 Matrix
In summary, the conversation revolves around finding the eigenvectors for a 3x3 matrix. It is suggested to solve for k1 in terms of k2 and then pick a value for k2, but the speaker is unsure how to do this with a 3x3 matrix. Another person suggests normalizing the eigenvectors by requiring them to have unit norm. The conversation ends with the speaker expressing confusion and asking for clarification on the methodology being used.
Saladsamurai
3,020
[tex]X'=\left[\begin{array}{ccc}4 & 1 & 4\\ 1 & 7 & 1\\ 4 & 1 & 4\end{array}\right]X[/tex]
After evaluating the determinant I get from the characteristic equation [itex]\lambda=0[/itex]
[tex]\lambda=\frac{15\pm \sqrt{119}*i}{2}[/tex]
Now here is where I am not sure where to go. I need to create an Eigenvector. I stared it off by plugging in for [itex]\lambda=0[/itex] giving the relationships:
[itex]4k_1+k_2+4k_3=0[/itex]
[itex]k_1+7k_2+k_3=0[/itex]
Now usually, in the case of a 2x2 matrix, I would solve for let's say k1 in terms of k2 and then just PICK some value for k2 and that would establish my Eigenvector.
I am a little confused as to how to do this with a 3x3. It would appear I have some sort of special case here since row 1 is the same as row 3, but I am unsure how to use that to my advantage?
Could someone just point me toward the next step?
Thanks!
Multiply the middle equation by 4 and then subtract from the top equation, and you see that
[tex]k_2 = 0[/tex] which implies that
[tex] k_1 = -k_3[/tex]
And there you have your vector defined up to one parameter, which is common. You are constructing U to go [tex]A=U^{\dagger}DU[/tex] or something like that right? So that you can go [tex]e^{tA} = U^{\dagger}e^{tD}U[/tex] arg I don't know if I have that right, but
you need to normalize your eigenvectors to do that and so you should fix your parameter by requiring that eigenvector to have unit norm.
See, I wish I knew what David was saying, but I don't. In this class, we tend to skip over terminology like 'normalization' and the proofs of our approaches, but we don't. We are dealt these 'cookie cutter' methods (I am sure these are common of Engineering programs) and are expected to just work with them.
It works fine and all until we run into something that does not fit the mold of what we have been dealing with.
Anyone else able to elaborate on what Davis was saying?
To construct U, it's not just laying out any old eigenvectors side by side, but using the eigenvectors with a norm or length/magnitude of unity or 1. That is to say each eigenvector [tex]x[/tex] for that matrix needs to satisfy
[tex]x^T x = 1[/tex]
For example if you found [tex]x = (-1, 1)[/tex] you will actually want to use [tex]x = 1/\sqrt{2}(-1, 1)[/tex] instead. Sorry for throwing the jargon around.
Yeah, see. Not even sure what this U is supposed to represent...I can see this is not going to go anywhere. This is my professor's methodology though. Not anyone else's.
Oh well why don't you just tell me what method you use. I thought you were diagonalizing a matrix, but I guess not??
1. What is a 3x3 matrix of DEs?
A 3x3 matrix of DEs is a system of three differential equations with three unknown functions. These equations are typically written in matrix form and can be solved simultaneously to find the values of the unknown functions.
2. How do you solve a 3x3 matrix of DEs?
To solve a 3x3 matrix of DEs, you can use various methods such as Gaussian elimination, Cramer's rule, or the inverse matrix method. These methods involve manipulating the equations in the matrix to isolate the unknown functions and solve for their values.
3. What are the applications of solving a 3x3 matrix of DEs?
Solving a 3x3 matrix of DEs is useful in many fields such as physics, engineering, and economics. It can be used to model and analyze complex systems with multiple variables and find solutions that satisfy all equations simultaneously.
4. What are the challenges of solving a 3x3 matrix of DEs?
Solving a 3x3 matrix of DEs can be challenging due to the complexity of the equations and the number of unknown variables. It requires a good understanding of linear algebra and differential equations, as well as proficiency in solving simultaneous equations.
5. Are there any tips for solving a 3x3 matrix of DEs more efficiently?
One tip for solving a 3x3 matrix of DEs more efficiently is to start by simplifying the equations and eliminating any unnecessary terms. It may also be helpful to use a graphing calculator or computer software to solve the equations and check your work. Additionally, practicing and familiarizing yourself with different solution methods can also improve efficiency.
  • Linear and Abstract Algebra
