How do you evaluate the integral of arcsin(sin(x)) from 0 to 2pi?
You will need to use a u-substitution with u = cos(x) for the outer integral.In summary, the conversation discusses an iterated integral with the given bounds and equations, and the attempt at a solution involves using trig substitution and u-substitution to solve the integral.
vDrag0n
int (1/(4-r^2)^0.5) dr dx, r=0 to 2sinx, x=0 to 2pi
How to continue the integral of x
I'm stuck at
int(arcsin(sinx)) dx, x=0 to 2pi
I'm stuck at
This is your iterated integral:
[tex]\int_{x = 0}^{2\pi}\int_{r = 0}^{2 sin(x)}\frac{1}{\sqrt{4 - r^2}}dr~dx[/tex]
I'm pretty sure you evaluated the inner integral incorrectly, most likely because you have a mistake in your trig substitution.
For this integral
[tex]\int_0^{2 sin(x)}\frac{1}{\sqrt{4 - r^2}}dr[/tex]
I get 2 sin(x)
That makes the outer integral pretty simple.
1. What is a double integral?
A double integral is a type of mathematical calculation used to find the area between a two-dimensional function and a specified region on the x-y plane.
2. How do you solve a double integral?
To solve a double integral, you must first evaluate the inner integral with respect to one variable, and then use the result as the integrand for the outer integral. This process is known as "integrating inside-out".
3. What is the purpose of solving a double integral?
The purpose of solving a double integral is to find the area under a two-dimensional curve over a specified region. This can be useful in a variety of real-world applications, such as calculating volumes or finding the center of mass of an object.
4. What are the limits of integration in a double integral?
The limits of integration in a double integral represent the boundaries of the region over which the integration is being performed. These limits can be determined by the shape and size of the region, as well as the function being integrated.
5. Are there any special techniques for solving difficult double integrals?
Yes, there are a few special techniques that can be used to solve difficult double integrals. These include changing the order of integration, using polar coordinates, and using trigonometric substitutions. It is important to familiarize yourself with these techniques in order to solve more complex double integrals.
