• Support PF! Buy your school textbooks, materials and every day products Here!
Solving a recurrence equation
  • Thread starter yoran
Hi, I'm trying to solve this recurrence equation.
1. Homework Statement
Solve [tex]y[k+2]+y[k]=sin(k)[/tex].
The answer is already given, it's
[tex]y[k]=c_1sin(\frac{\pi}{2}k) + c_2cos(\frac{\pi}{2}k) + \frac{sin(k)+sin(k-2)}{2(1+cos(2))}[/tex]
2. Homework Equations
3. The Attempt at a Solution
First I solve the homogeneous equation.
[tex]y[k+2]+y[k]=0[/tex].
The characteristic function is
[tex]r^2+1=0[/tex]
This has two complex roots [tex]r=i[/tex] and [tex]r=-i[/tex].
Thus the general solution is
[tex]y[k]=c_1(i)^k+c_2(-i)^k[/tex]
If you change the notation for the complex numbers, then it gives
[tex]y[k]=c_1(cos(\frac{\pi}{2}k)+isin(\frac{\pi}{2}k)) + c_2(cos(\frac{-\pi}{2}k)+isin(\frac{-\pi}{2}k))[/tex]
After grouping together it gives
[tex](c_1+c_2)cos(\frac{\pi}{2}k) + (c_1-c_2)isin(\frac{\pi}{2}k)[/tex]
Apparently, the answer is without complex numbers so I guess they only keep the real part. Then it must be so that
[tex]c_1-c_2=0\Leftrightarrow c_1=c_2[/tex]
Then I get as solution
[tex]y[k]=2c_1cos(\frac{\pi}{2}k)[/tex]
which is not the same solution as the general solution in the answer. What did I do wrong?
I also tried to find a particular solution for the non-homogeneous equation. I tried as a solution
[tex]y[k]=\alpha sin(k)[/tex]
with [tex]\alpha[/tex] the parameter to determine. I don't this is the right solution. Can anyone help me with this problem?
Thanks,
Yoran
Answers and Replies
334
They don't "only keep the real part". Plug the solution back into the homogeneous equation; the sine part falls out without imposing any constraint on c1 and c2.
118
Hi,
Thanks for your quick reply. I tried to do what you told me but when I plug it into the homogeneous equation, everything cancels out! I get 0=0. This is what I did:
We have that
[tex]y[k]=(c_1+c_2)cos(\frac{\pi}{2}k)+(c_1-c_2)isin(\frac{\pi}{2}k)[/tex]
I plug it into
I get
[tex](c_1+c_2)cos(\frac{\pi}{2}(k+2))+(c_1-c_2)isin(\frac{\pi}{2}(k+2))+(c_1+c_2)cos(\frac{\pi}{2}k)+(c_1-c_2)isin(\frac{\pi}{2}k)=0[/tex]
Because
[tex]cos(\theta + \pi)=-cos(\theta)[/tex] and
[tex]sin(\theta + \pi)=-sin(\theta)[/tex]
I get that
[tex]-(c_1+c_2)cos(\frac{\pi}{2}k)-(c_1-c_2)isin(\frac{\pi}{2}k)+(c_1+c_2)cos(\frac{\pi}{2}k)+(c_1-c_2)isin(\frac{\pi}{2}k)=0[/tex]
which makes
[tex]0=0[/tex]
How come?
334
Actually, you are correct. That was a silly suggestion of me, because 0=0 simply confirms your solution satisfies the equation from which you derived the solution. I will edit this post if I come up with something.
Edit: Wow I had been reading it wrong for a good 45 minutes, sorry! Consider complex coefficients and make the substitution d1=c1+c2 and d2=i(c1-c2).
Can you find the particular solution from here?
Hi,
Yeah of course... just give different names as they are just parameters... Thanks a lot.
I tried the substitution [tex]\alpha sin(k)[/tex] because there is [tex]sin(k)[/tex] on the right side of the equation. However, I can't find the right answer. This is what I have done:
Try
Plug it into the equation:
[tex]\alpha sin(k+2) + \alpha sin(k) = sin(k)[/tex]
Then we get
[tex]\alpha = \frac{sin (k)}{2sin(k+1)cos(1)}[/tex]
by using the identity
[tex]sin(\theta) + sin(\alpha) = 2sin(\frac{\theta + \alpha}{2})cos(\frac{\theta - \alpha}{2})[/tex]
The answer for [tex]\alpha[/tex] is obviously not the right answer.
Did I make the wrong substitution?
118
Anyone?
tiny-tim
25,789
249
Try
Hi yoran! :smile:
Try [tex]y[k]=\alpha\,sin(k\,-\,1)[/tex] . :smile:
118
Ok, I tried
[tex]y[k]=\alpha \sin(k-1)[/tex].
Then I get that
[tex]\alpha = \frac{1}{2\cos 1}[/tex]
So given the solution for the homogeneous equation and this solution, I have that
[tex]y[k]=c_1\sin{\frac{\pi}{2}k} + c_2\cos{\frac{\pi}{2}k} + \frac{1}{2\cos{1}}\sin{k-1}[/tex]
But the answer should be
[tex]y[k]=c_1\sin{\frac{\pi}{2}k} + c_2\cos{\frac{\pi}{2}k} + \frac{\sin{k}+\sin(k-2)}{2(1+\cos{2})}[/tex]
Where does it go wrong in my solution?
tiny-tim
25,789
249
Hi yoran! :smile:
…I have that
:rofl: But they're the same! :rofl:​
Standard trig equation: 1 + cos(2) = 2cos²(1).
So [tex]\frac{\sin{k}+\sin(k-2)}{2(1+\cos{2})}[/tex] = … ? :smile:
118
Hehe, of course... Thanks a lot!
[tex]\frac{\sin{k}+\sin(k-2)}{2(1+\cos{2})}=\frac{2\sin(k-1)\cos(1)}{4\cos^2(1)}=\frac{\sin(k-1)}{2\cos 1}[/tex]
Related Threads for: Solving a recurrence equation
  • Last Post
  • Last Post
  • Last Post
