Solving a surface integral
44
Solve the surface integral ##\displaystyle \iint_S z^2 \, dS##, where ##S## is the part of the paraboloid ##x=y^2+z^2## given by ##0 \le x \le 1##.
First, we make the parametrization ##x=u^2+v^2, \, y=u, \, z = v##, so let ##\vec{r}(u,v) = \langle u^2 + v^2, u, v \rangle##, then through computation ##| \vec{r}_u \times \vec{r}_v | = \sqrt{1+4u^2+4v^2}##, and so ##\displaystyle \iint_S z^2 \, dS = \displaystyle \iint_D v^2 \sqrt{1+4u^2 + 4v^2} \, dA##, where ##D = \{(u,v) \, | \, u^2 + v^2 \le 1 \}##. However, this is where I get stuck, because I want to use polar coordinates to evaluate the latter integral, but I am not sure whether to use ##v = r \sin \theta## or ##v = r \cos \theta##
Answers and Replies
member 587159
It doesn't matter what you use. If you choose ##v = r\cos(\theta)##, then you will have polar coordinates in the ##zy##-plane. Thus, the angle starts from the ##z##-axis. In the other case, in the ##yz##-plane, the angle starts at the ##y## axis. The funny thing is that you don't even have to understand what's happening geometrically, as it is always a full rotation.
However, I should add, that there is a better parametrisation: (use cylindrical coordinates)
##\begin{cases}x = (R\cos(\theta))^2 + (R\sin(\theta))^2 = R^2 \\ y = R\cos(\theta) \\z=R\sin(\theta)\end{cases}##
where ##R \in [0,1], \theta \in [0, 2\pi]##
44
Would there every be a case when it matters which I choose? For example, what if I just had
##\displaystyle \iint_D v \, dA##, where ##0 \le v^2 + u^2 \le 25##? Then wouldn't it matter?
member 587159
It never matters if you can correctly interpret what's happening geometrically. In this case, it doesn't matter since ##\theta \in [0,2\pi]##. If ##\theta \in [0,a]## with ##a < 2\pi##, things get trickier.
Your question is easier to answer if you think just in the original 2D ##xy## plane (that's how I think about it. If we use polar coordinates in yz, then just act as the the yz plane is the xy plane and change y,z accordingly).
Likes Mr Davis 97
Related Threads on Solving a surface integral
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
