Homework Help: Solving for F2
  1. Feb 20, 2010 #1
    This is a physics problem where I need to solve for F1 and F2. What am I doing wrong because I am not getting the right answer for F2. It's not even supposed to be negative.
  3. Feb 21, 2010 #2
    Redbelly98
    Staff Emeritus
    There are two problems here.
    1. In the last step, you incorrectly evaluated the denominator,
    -sin(26.6) + cos(26.6)*cos(21.8)/sin(21.8)​
    It does not equal 2, as you seem to have calculated.
    2. The correct answer for F2, given the 2 equations you are starting with, is negative. If that is wrong, there is a problem in how you derived those two equations.
  4. Feb 21, 2010 #3
    Ok, here's how the force components are set up. Are the equations right for it?
  5. Feb 21, 2010 #4
    Redbelly98
    Staff Emeritus
    Looks like the equations are set up correctly, at least on the left-hand sides. So I have two followup questions for you:
    1. Why must the forces sum to zero?
    2. Why can't F2 be negative? That would simply mean it points in the upward-rightward direction, instead of downward-leftward as drawn.
    By the way, in the future, it would be helpful if you post the actual full problem statement :smile:
  6. Feb 21, 2010 #5
    I don't know the theory behind why but that's how I was taught to solve these kind of problems where I need to find the magnitudes of the force components.
    I see what you mean. It's just that the book didn't give the answer as negative so I got confused. All it said was 1180 N (that's rounded) with no negative sign or direction given.
  7. Feb 21, 2010 #6
    Redbelly98
    Staff Emeritus
    Well, it depends what the question is, but I have absolutely no idea what was being asked.
    Have you recalculated F2 based on what I said in Post #2?
  8. Feb 21, 2010 #7
    Yeah, I did recalculate and I got -1176.
    Here's how the question reads:
    Two forces F1 and F2 are applied as shown in Fig. 7.31(which is the diagram I posted above). The resultant R has a magnitude of 850 N and acts in the direction shown in the figure. Determine the magnitudes of F1 and F2.
    That's all it says.
  9. Feb 21, 2010 #8
    Redbelly98
    Staff Emeritus
    You have magnitude that agrees with the final answer now, so that is progress. But, you set up the equation wrong earlier. The resultant is, by definition, the sum of the other vectors F1 and F2.
    Instead of
    F1x + F2x + Rx = 0​
    it should be
    F1x + F2x = Rx
    and similarly for the y-components.
