Solving Identities Homework: Proving 1/1+sinx=sec2x - tanx/cosx
  • Thread starter ritagogna
In summary, the conversation is about a student who needs help proving two identities in grade 12. They have been working on the problem for 2 hours and are stuck. After discussing the problem, they realize that one of the identities should be cos2x instead of cos squared 2x. The expert summarizer advises the student to write out tanx and secx in terms of sinx and cosx, and then multiply the equation to get rid of the denominators. The student then realizes that the correct equation is 1-sinx/cos2x and they are unsure of where to go from there.
ritagogna
hey i really need some ones help i need to prove these 2 identities. I am in grade 12 and I've been working on these questions for almost 2 hours and keep failing pleasezz help
b. 1/1+sinx = sec2x - tanx/cosx
-secx=1/cosx
-tanx=sinx/cosx
-sin2x+cos2x=1
-cscx=1/sinx
So i tried proving the identity and got stuck...
i picked one side which was 1/1+sinx
then i got the conjugate
=1/1+sinx(1-sinx/1-sinx)
=1-sinx(1/sinx)
and this is where i have no idea what to do because i need to make it equal to sec2x-tanx/cosx
By sec2x do you mean sec2x? If so, the equation is [tex]\frac{1}{1+sinx}=sec^2x-\frac{tanx}{cosx}[/tex].
Now, my advice would be to write out tanx and secx in terms of cosx and sinx. Then multiply the equation to get rid of the denominators. Try this and post what you get.
I take it that you mean:
[tex]\frac{1}{1+\sin(x)}\frac{1-\sin(x)}{1-\sin(x)}[/tex]
=1-sinx(1/sinx)
I'm not sure of how you got this (or even of how to read it!), but it definitely looks wrong. You should multiply across the top and across the bottom in my expression above. Try that, and post what you get.
so i worked it out and I am pretty sure its 1- sinx/ cosx
Nope, the cosine should be squared.
no the equation is exacly what cristo got
ok so its 1-sinx over cos2x
No, I'm talking about the part of your solution that I quoted.
wait no its 1/cos2x-sinx/cosx
Do you mean cos2(x)? If so, then you're right. But if you mean cos(2x), then you're not right.
no i mean cos squared 2 x but i still haven't solved the identity and i don't know where to go from here because ill just be making the equation more complicated by converting the identities
That's wrong. When you multiply [itex]1+\sin(x)[/itex] by [itex]1-\sin(x)[/itex], you get [itex]1-\sin^2(x)=\cos^2(x)[/itex]. The argument of the cosine is not [itex]2x[/itex].
What is the purpose of solving identities homework?
The purpose of solving identities homework is to practice using algebraic manipulations and trigonometric identities to simplify expressions and prove that they are equal to each other.
What are the steps involved in solving identities homework?
The general steps for solving identities homework include:
  1. Simplifying each side of the equation using algebraic manipulations
  2. Applying known trigonometric identities to both sides of the equation
  3. Continuing to manipulate and simplify both sides until they are equivalent
  4. Writing a concluding statement to show that the original equation is equivalent to the simplified expression
What is the meaning of the equation 1/1+sinx=sec2x - tanx/cosx?
This equation is an identity, which means that it is true for all values of x. It is a trigonometric identity that shows the relationship between the cosecant, secant, tangent, and cosine functions.
What are some common mistakes to avoid when solving identities homework?
Some common mistakes to avoid when solving identities homework include:
  • Forgetting to apply the distributive property when simplifying expressions
  • Making arithmetic errors when combining terms
  • Not using parentheses correctly when substituting in values for trigonometric functions
  • Forgetting to check the domain of the original equation and the simplified expression
How can I improve my skills in solving identities homework?
To improve your skills in solving identities homework, it is important to practice regularly and seek help when needed. It can also be helpful to review the properties and rules of algebra and trigonometry, as well as common trigonometric identities. Additionally, trying different approaches and methods to solve equations can help develop problem-solving skills.
  • Precalculus Mathematics Homework Help
  • General Math
