Solving for x in y=2x-3/(2x-4)^2: Tips and Hints for Solving Equations
  • Thread starter e^(i Pi)+1=0
  • Tags
    Terms
In summary, you need to find a quadratic equation that y is in one of the coefficients. Once you have that, solving for x is a fairly simple process.
e^(i Pi)+1=0
247
How would I solve this for x? I've been trying for a while now, and
i can't seem to get anywhere. I just need some kind of hint.
y=2x-[itex]\frac{3}{(2x-4)^2}[/itex]
Multiply both sides of the equation by [itex](2x- 4)^2[/itex] and you will have a cubic equation for x. There is a formula for the solution of general cubic polynomial equations but it is very complicated.
http://en.wikipedia.org/wiki/Cubic_function
But then I'm left with y(2x-4)^2 on the left hand side.
The cubic factors to 8(x-1.5)(x-[itex]\frac{5+\sqrt{21}}{4}[/itex])(x-[itex]\frac{5-\sqrt{21}}{4}[/itex])
I just gave it a shot.
Expand y(2x-4)^2 and take everything on one side, you will get a cubic equation, solve it taking x as variable. This will take a little time, there must be a simpler way too.
Yes, you do. So what? y will be part of the coefficients of the polynomial so the solution will involve y.
We have 0=8x3-32x2+32x-3-4x2y+16xy-16y
Here are some forms I've managed to simplify it to
0=(x-2)2(8x-4y)-3
8x(x-2)2=4y(x-2)2+3
I just cannot seem to isolate x.
If you really want to solve for x, you'll have to use the method shown in the wiki link Halls gave earlier. Wolframalpha gave a complicated-looking answer...
0=(x-2)2(8x-4y)-3
8x(x-2)2=4y(x-2)2+3
You cannot isolate x by such methods. It involves complex numbers, which is described in HallsOfIvy's link. :smile:
0=(x-2)2(8x-4y)-3
8x(x-2)2=4y(x-2)2+3
Somehow you are not "getting it", so let's look at a simpler case:
[tex] y = 2x - \frac{3}{2x-4}.[/tex]
If you multiply through by the denominator you get [itex](2x-4)y = 4x^2-8x-3,[/itex] or
[itex] 4x^2 -(8+2y)x + (4y-3) = 0,[/itex] so you get a quadratic equation for x with "y" in some of the coefficients. That means that the solution will be a reasonably complicated function of y:
[tex] x = 1 + \frac{y}{4} \pm \frac{\sqrt{y^2 - 8y + 28}}{4}.[/tex]
The same type of thing happens in your original problem, but now you end up with a cubic equation for x (with y in some coefficients), so the final solutions for x are much, much more complicated.
RGV
Thank you! I didn't recognize that there was a quadratic hidden in there.
There isn't!
RV's simpler example involved a quadratic, but your original problem involves a cubic, as was pointed out to you by Ivy in post #2.
(BTW, your username is my favourite equation ever.)
Yeah, I get it now, the Xs factor out to make a cubic. I was just full of fail this thread.
[tex]
\frac{3}{(2 x - 4)^2} = 2x - y
[/tex]
[tex]
3 = (2 x - 4)^2 (2 x -y)
[/tex]
[tex]
3 = 4 (2 x - y) (x^2 - 4 x + 4)
[/tex]
[tex]
3 = 8 x^3 - 4 (y + 8) x^2 + 16 ( y + 2) \, x - 16 y
[/tex]
You get the following cubic equation:
[tex]
8 x^3 - 4 (y + 8) x^2 + 16 ( y + 2) \, x - (16 y + 3) = 0
[/tex]
EDIT:
I made a typo and gave a wrong equation. I believe it is corrected now.
Do you know how to solve cubic equations?
Dickfore said:
[tex]
[/tex]
[tex]
3 = (2 x - y)^2 (2 x -y)
[/tex]
Umm... no.
Dickfore said:
[tex]
[/tex]
[tex]
[/tex]
EDIT:
Keep trying...! :smile:
EDIT: My mistake, this is correct. :redface:
I believe that step is correct.
Bugger me. My sincerest apologies! :redface: You are of course correct.
(I went blind for a second and misread you.)
What is the first step in solving this equation?
The first step in solving this equation is to distribute the exponent in the denominator using the power rule.
How do I get rid of the fraction in this equation?
To get rid of the fraction, multiply both sides of the equation by the least common denominator (LCD) of the fraction.
What is the next step after getting rid of the fraction?
After getting rid of the fraction, combine like terms and simplify the equation as much as possible.
What should I do if I end up with a quadratic equation?
If you end up with a quadratic equation, use the quadratic formula or factor the equation to solve for x.
Are there any common mistakes to avoid when solving this type of equation?
One common mistake to avoid is forgetting to check for extraneous solutions, which may occur when multiplying both sides of the equation by the LCD. It is important to plug in the solutions back into the original equation to make sure they are valid solutions.
