Solving position vectors using given speed.
A particle P starts at the position vector 4i + j and moves to 12i - 11j with a speed of 4 m/s. The equation relating the initial and final position vectors is established as 12i - 11j = 4i + j + vt. After simplifying, it is determined that 8i - 6j = vt, leading to the calculation of the magnitude of the vector. The magnitude is found to be 10, resulting in the time t being calculated as 2.5 seconds. The discussion also clarifies the relationship between the magnitude of a scalar and a vector.
riddle
A particle P starts at the point with position vector 4i + j. P moves with constant velocity vm/s. After t seconds, P is at the point with position vector 12i - 11j. Find t if the speed of P is 4m/s.
n/a
6i - 3j = -2i + 3j + vt
=> 8i - 6j = vt
=> 8i - 6j = *bleh. and now I'm stuck.*
n/a
=> 8i - 6j = vt
Use the formula in the attachment in your other problem, r = r0 + vt.
In your attempt, where did 6i - 3j and -2i + 3j come from? They don't have anything to do with this problem.
At 0 seconds, the particle is at r0 = 4i + j. After t seconds, r = 12i - 11j.
So 12i - 11j = 4i + j + v t.
Start with this equation, simplify it a bit, and use the idea that if two vectors are equal, their magnitudes are also equal.
HAHAHAHA. This is the second time I've done this. *facepalm* I copied the wrong vectors.
r0 = -2i + 3j, and r = 6i - 3j.
So, 8i - 6j = tv
And I really have no idea what to do to proceed.
EDIT: Ok. So,
8i - 6j = vt
Both sides are equivalent.
Speed = |v|
So,
| 8i - 6j | = |vt|
=> 10 = 4t
=> t= 2.5
So t=2.5 seconds?
But can you just multiply like that?
What I mean to say is that is |vt| = |v| * t ?
So, 8i - 6j = tv
EDIT: Ok. So,
8i - 6j = vt
Both sides are equal. There is a difference. Statements can be equivalent (same truth values); expressions can be equal (or less than, greater than, etc.).
riddle said:
Speed = |v|
So,
| 8i - 6j | = |vt|
=> 10 = 4t
=> t= 2.5
So t=2.5 seconds?
Yes, the magnitude of a scalar times a vector is the scalar times the magnitude of the vector.
More precisely, |kv| = |k||v|. This takes into account the possibility that k is a negative number.
Wait, don't you mean |kv| = k * |v|
Or are you just implying that the magnitude of a scalar is the sacalr itself, i.e, |k| = k
*sigh* I need some sleep.
|k| means the absolute value of the scalar k, which is always positive, like the magnitude (length) of a vector. So if k = -5, then |k| = 5. If k = 5, |k| = 5. It just means, throw away the minus sign if there is one.
No, I mean exactly what I wrote, namely that |kv| = |k||v|. The magnitude of a scalar is its distance from 0.
For example, let v = 3i + 4j, so |v| = 5.
|-2v| = |-2(3i + 4j)| = |-6i - 8j)| = \sqrt((-6)2 + (-8)2) = \sqrt(36 + 64) = \sqrt(100) = 10 = 2|v|
Oh.
I can't wait till I'm as smart as you guys. *anticipation emoticon*
EDIT: And thanks for all your help.
