Solving Sonar equation
  • Thread starter Spookie71
A ship sends a sonar signal to the bottom of the ocean, 4000 m below. The speed of sound in the seawater under the conditions of the problem is 1500 m/s How much time elapses between the transmission of the signal and the reception of its echo?
Given: [tex]^V{}_{s}[/tex] = 1500 m/s
Δd = 4000 m (The speed of sound in the water in the given conditions
Required: Δt
Analysis: [tex]^V{}_{s}[/tex]= [tex]\frac{\Delta d}{\Delta t}[/tex]
I drop the [tex]\Delta d[/tex] down to the denominator and also bring it across to be the denominator on the other side.
[tex]\frac{^V{}_{s}}{\Delta d}[/tex] =[tex]\frac{\Delta d}{\Delta t \Delta d}[/tex]
I cancel out the [tex]\Delta d[/tex] and end up with
[tex]\Delta d[/tex]= [tex]\frac{^V{}_{s}}{\Delta t}[/tex]
I know my math isn't correct here because I have the correct answer in front of me
I just don't know how they did it. This is what the textbook has
[tex]\Delta t[/tex]= [tex]\frac{\Delta d}{^V{}_{s}}[/tex]
Can you please explain to me how they did this.
Thank you
Scott
Answers and Replies
You have [itex]v_s/d = 1/t[/itex] and if you want to multiply both sides by d, you will also want to multiply both sides by t (you did something weird). Your first eqn. is okay, but the second one is wrong. So you will want to find the time it takes to go to the bottom, and then back up (they happen to be equal after a moments thought) to find the total time.
Related Threads on Solving Sonar equation
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
