Solving the DE
  • Thread starter roam
roam
1,271
Hello!
Here's a question I was doing but I'm not sure if I'm right...
It says "solve" the following differential equation:
[tex](x^2 +1) \frac{dy}{dx} = 0[/tex]
So, this is what I've done:
We put it in form [tex]\frac{dy}{dx} +p(x)y = q(x)[/tex]
Then we divide it by x^2 +1 to obtain:
[tex]\frac{dy}{dx} + \frac{x}{x^2 +1} y = \frac{1}{x^2 +1} \times 0[/tex]
you know , in standard form where p(x) = x/x^2 +1
Integrating factor is:
[tex]exp[\int p(x) dx = exp[\frac{x dx}{x^2 +1}[/tex]
[tex]= exp[ln(x^2 +1)^{2}][/tex]
[tex]= (x^2 +1)^{2}[/tex]
Multiplying the DE by the integrating factor;
[tex](x^2 +1)^{2} \frac{dy}{dx} +x(x^2 +1)y = x . (x^2 +1)^{2}[/tex]
Now we integrate:
[tex]\frac{d}{dx} [(x^2 +1)^{2} y] = x^3 +x[/tex]
=> [tex][(x^2 +1)^{2} y] = \frac{x^4}{4} + \frac{x^2}{2} + c [/tex]
Am I right? Please correct me if I'm wrong...
Thank you,
Answers and Replies
Vid
402
The only answer is y = c.
You have two things being multiplied together equaling zero. This means that either (x^2+1) = 0 or dy/dx = 0. In the first case, the equation is only true when x = +-i which isn't very useful since we solve DEs over an interval and would also allow for y to be any function of x (again not very useful). In the second case, dy/dx = 0 thus y = c is the only solution.
You can see your solution doesn't work by just plugging it into the original equation.
roam
1,271
Yes, maybe but could you please show me how the actual calculation goes till we get to y = c? :rolleyes:
Thank you.
Vid
402
dy/dx = 0 from my explanation above. The only (continuous) functions with zero derivatives are constant functions.
roam
1,271
The correct answer at the back of the book is [tex]y = \frac{c}{\sqrt{x^2 +1}}[/tex].
I get your explanation, Vid. But the question is asking me to show working and calculations.
HallsofIvy
43,021
971
No, you haven't understood what he is saying. Vid is trying to tell you is that, since x2+ 1 is never 0, you can divide on both sides by it to get dy/dx= 0 which, integrating, gives y= c, a constant. That should be pretty simple mathematics.
[itex]y(x)= c\sqrt{x^2+1}[/itex] satisfies the equation [itex](x^2+1)dy/dx= xy[/itex], not 0.
roam
1,271
Yes, Thanks. :smile:
2) Solve: [tex]\frac{dy}{dx} + 2xy = x[/tex]
This is what I think;
[tex]\int 2x dx = x^2[/tex]
So we multiply both sides by [tex]e^{x^2}[/tex]
[tex]\frac{d}{dx} (e^{x^2} y) = xe^{x^2}[/tex]
[tex]e^{x^2}y = \frac{1}{2}e^{x^2} + c[/tex]
=> [tex]y = c e^{x^2} - \frac{1}{2}[/tex]
c is a constant.
I appreciate that if you could tell me if I made any errors or mistakes..
Defennder
2,592
It's correct up to here.
This is incorrect. You were dividing the RHS by [tex]e^{x^2}[/tex] right? You should get [tex]\frac{1}{2} + ce^{-x^2}[/tex] instead.
roam
1,271
[tex]\frac{1}{2} + ce^{-x^2}[/tex] or [tex]\frac{1}{2} + ce^{x^2}[/tex]?
Anyway, Thanks a lot for your attention!
Defennder
2,592
It's the first one. That is what you get when you divide c by [tex]e^{x^2}[/tex]
roam
1,271
Of course!
Many thanks...
roam
1,271
For the first question, if the question was: [tex](x^2 +1) \frac{dy}{dx} +xy = 0[/tex]
then the solution would be: [tex]y = \frac{c}{\sqrt{x^2 +1}}[/tex]
Hmm, so how do we get that? (that was my question but I missed out +xy).
Does any of my working in the very above post make any sense?
I don't know how do this question so I get [tex]y = \frac{c}{\sqrt{x^2 +1}}[/tex] ...
Defennder
2,592
What's the integrating factor in this case? Remember you must first express the DE in the form: [tex]\frac{dy}{dx} + P(x)y = Q(x)[/tex]
Your answer appears to be correct, so what's the problem?
HallsofIvy
43,021
971
So [tex]\frac{dy}{dx}= x- 2xy= x(1- 2y)[/itex]
[tex]\frac{dy}{1- 2y}= xdx[/itex]
c is a constant.
roam
1,271
Yes I did put it in the standard form and I found the integrating factor
standard form : [tex]\frac{dy}{dx} +p(x)y = q(x)[/tex]
multiplying it by the integrating factor;
Now we integrate: [tex]\frac{d}{dx} [(x^2 +1)^{2} y] = x^3 +x[/tex]
I get: [tex][(x^2 +1)^{2} y] = \frac{x^4}{4} + \frac{x^2}{2} + c [/tex]
But this is wrong since the correct answer should be: [tex]y = \frac{c}{\sqrt{x^2 +1}}[/tex]
I don't know how to get that.:cry:
Vid
402
Int(x/(x^2+1) = 1/2ln(x^2+1) = ln|(x^2+1)^(1/2)| not squared. The right side is just zero so the integral is just c; solve for y to get the right answer. Also this DE is easier as a separable equation instead of a first order linear.
HallsofIvy
43,021
971
There is no need to use integrating factors: you have a separable equation.
Subtractiong xy from both sides and dividing on both sides by [itex]x^2+ 1[/itex]
[tex]frac{dy}{dx}= \frac{xy}{x^2+ 1}= \right(\frac{x}{x^2+1}\right) y[/tex]
[tex]ydy= \frac{x dx}{x^2+1}[/tex]
